Backpressure ???
Old Nov 2, 2005 | 07:38 PM
lude98SH's Avatar
Default Backpressure ???
This topic has been goin over and over but I keep hearing different things. Is backpressure a good thing on an NA setup? or does it matter on how much power ur putting out ? Or does less backpressure just mean less low end but better top end ?
Old Nov 2, 2005 | 08:20 PM
mgags7's Avatar
use an exhaust that is the same size as the collector on your header....you cant go wrong like that....
Old Nov 2, 2005 | 08:32 PM
cpforyou's Avatar
Default Re: Backpressure ??? (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">This topic has been goin over and over but I keep hearing different things. Is backpressure a good thing on an NA setup? or does it matter on how much power ur putting out ? Or does less backpressure just mean less low end but better top end ? </TD></TR></TABLE>
You want NO BACKPRESSURE.
So why do you lose power if your piping is too big? It is because there is an OPTIMAL EXHAUST VELOCITY to make power at a certain range. This velocity is 300 feet per minute.
Lets say you have a header with 2" primaries, 2.5" secondaries, and 3" collector on an N/A car with little mods. Because the pipes are so big, the velocity of the gasses are SLOWER. Hence you lose power.
Now lets say you have a header with 1" primaries, 1.5" secondaries, and a 1.75" collector on an N/A car with little mods. Becuase are too small, you have a restriction, which makes you lose power. However, at lower RPMs, somewhere along the power curve, you will be at 300 fpm, which is why you feel better low-end power, but worser top-end power.
So bascially, the main factors that determin fpm is displacement and rpm. Bigger displacement = more fpm throughout the rpm band. Higher rpm = more fpm (directly proportional).
blackcivic11
24
Mar 20, 2008 09:23 AM
DARKTEG_
Sep 3, 2006 08:30 AM
accordselux
Mar 13, 2004 08:25 AM
tr4il
Honda Motorcycles
Jun 24, 2002 10:44 PM
