witch one?
Old Nov 4, 2005 | 03:29 PM
BDRphaSe2's Avatar
Default witch one?
ok, i have a usdm 4th gen 94 with a jdm h22a swap, very lightly moded just basic h/i/e and a apexi super vafc II, witch ecu should i go with or stick with the jdm h22 ecu ??? thanks
Old Nov 4, 2005 | 03:52 PM
EGmikeH22's Avatar
* B A N N E D *
if you want to tune you're almost stuck with a P72 GSR since its the only one that can (stock) control IABs
and its easily chippable
Old Nov 4, 2005 | 04:06 PM
lude_behavior's Avatar
Default Re: witch one? (BDRphaSe2)
The P13 is fine if your using a VAFC, you could replace your ECU if you were going Hondata or something of that nature, but you don't need to.
Old Nov 5, 2005 | 03:22 PM
MadCityLude
Guest
Posts: n/a
Keep the P13 unless you want hondata. As far as I know its as easily chippable as the p72 and you already got it so why change?
Good Luck
spurge
Nov 3, 2006 09:37 AM
RTW DC2R
Dec 15, 2004 01:41 PM
95accordh22a
Dec 2, 2004 06:12 AM
URNVS
Aug 19, 2004 10:01 AM
1hotintegra
Jun 29, 2003 03:24 PM
