Motor Mount
Old Nov 2, 2005 | 04:03 PM
92vteclude's Avatar
Default Motor Mount
Will a 1992 h23 motor mount fit the 01 h22? I have a 92 lude which had the h23 and now has the newer motor, and I can feel a thud when I take off
Old Nov 2, 2005 | 04:46 PM
BB6racer's Avatar
it should mount fine. the h and f motors/trannys are interchangable, check that all the mounting bolts are tightened.
Old Nov 2, 2005 | 06:31 PM
92vteclude's Avatar
thanks, I will do that
Old Nov 2, 2005 | 06:32 PM
92vteclude's Avatar
Would you reccomend poly mounts? I want something that is stiff...
Old Nov 2, 2005 | 06:49 PM
plikit's Avatar
Default Re: (92vteclude)
if you need to replace them you might as well go with stiffer polyurethane ones. just about any will do.
Davanca
May 28, 2013 11:37 AM
fatfurious2
Mar 6, 2009 02:09 PM
Jason-K
May 10, 2007 12:58 AM
NoVALude
Apr 11, 2006 08:28 AM
SIckH22Atch
Jul 7, 2004 03:23 PM
