head gasket Questions h22
ok so i took off my head gasket last night and i forgot to reference its correct position. It almost looks symetrical. Anyone know the correct position so t hat all the holes line up right?
Also...does my head gasket look bad likeit needs to be replaced?
When putting a head gasket on, is it recommended to use a silicone based sealant with head gasket? If so...where would i put the silicone selant?
i gave it a few minutes...deliii.com isnt up.
well thanks for being helpful and rude at the same time. IS there anyone that is willing to help. Cuz thats what were all here for, not to be told to get a Helms and "read it".
Re: (driftmaster04)
on the head gasket it says UP on it. it looks like the headgasket is upside down. and 92hondalude is right get a new head gasket. and dont put silacone on it LOL!!! goodluck
Re: head gasket Questions h22 (draconx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by draconx »</TD></TR><TR><TD CLASS="quote">RTV!!! its a blue silacone (spelt wrong) and put it on both sides and let it dry</TD></TR></TABLE>
i really hope that was a joke, might as well just lay down a bead of GE window & door caulk and cal it a day
and you NEED to replace head gaskets when ever you pull the head, its not even the surface of the head gakset that you need to look at, the metal looses its springyness, and will not seal properly
DrGrEeNtHuMb
03-16-2009 03:58 PM
