Bounce Shift
Old Nov 29, 2005 | 06:37 AM
lude98SH's Avatar
Default Bounce Shift
I have another thread where I talked about my motor hesitating. Anyway I wanted to rev it up and see where it felt weak or lost power. Anyway when going into 3rd i grinded the gears pretty bad. I shifted the same way as normal but it kind of bounced before i got it in gear. I am changing the tranny fluid this week, but do you think that will do anything if the syncros themselves are bad ? Unless I use syncromesh. What do u guys think ?
Old Nov 29, 2005 | 03:58 PM
lude98SH's Avatar
Default Re: Bounce Shift (lude98SH)
bump
Old Nov 30, 2005 | 03:49 PM
lude98SH's Avatar
bump
Old Dec 1, 2005 | 01:00 AM
K-Spec's Avatar
what do you mean by "bounce"?
Old Dec 1, 2005 | 05:56 AM
optikal_blitz's Avatar
Default Re: Bounce Shift (khalal538)
Shifter moves forward and backward? (toward the dash, then away) when you come off the throttle and step back on it. Am i right?
my mom's camry does this (91 ) and my guess is a bent shifter fork
Old Dec 1, 2005 | 06:11 AM
lude98SH's Avatar
Default Re: Bounce Shift (optikal_blitz)
I go to put it into gear and it locks me out of the gear. Its not always only every once and awhile usually if i shift quickly and sometimes going into 1st gear from a stop or roll. Its not really a bounce its more of a blockage or locking out of the gear for some reason. Syncros ?
Old Dec 1, 2005 | 06:14 AM
mgags7's Avatar
most first gears wont let you in unless you are damn close to a stop, or just learn how to play with the clutch....
it could be a syncro, but my guess is that you just have something jammed between things on the gear somewhere....
Old Dec 1, 2005 | 08:29 AM
K-Spec's Avatar
Is it easy to get into first gear when you're stopped (and I mean dead stop)?
Old Dec 1, 2005 | 12:07 PM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">Is it easy to get into first gear when you're stopped (and I mean dead stop)? </TD></TR></TABLE>
95% of the time yes. But every once in awhile it wont go into 1st. Usually if i put it back in neutral let out the clutch and try it again it does. I have no idea why this is? I kinda pump the clutch.
Old Dec 1, 2005 | 08:07 PM
K-Spec's Avatar
I think your issue is a normal one. The reason why your tranny locks out is because it is a safety feature to prevent the user from messing up the tranny. Same with reverse, if you try to go into reverse, you will probably get in 95% of the time. Go ahead and try it...
Soltis
Acura TL, RL & ZDX
May 26, 2010 08:56 PM
masruque
Jul 15, 2009 07:17 AM
DC5mike
Jun 27, 2008 06:16 PM
Understeer
Nov 5, 2002 09:33 AM
b20civic
Sep 8, 2002 11:33 PM
