power issues
Old Nov 22, 2005 | 09:48 AM
darkd1gt's Avatar
Default power issues
hey i am having a problem with a power type surge. When the car warms up at low rpms and slowing down the lights on the dash get dim, but when i hit the gas again it get bright. Then go back to normal untill loss of speed again.
Does this sound like a battery or alternator issue or something else? I had both checked out and they seemed to be fine.
Old Nov 22, 2005 | 09:55 AM
AndyD's Avatar
Default Re: power issues (mattspivey)
My guess would be the alternator. You had them tested and they said it was fine?
Old Nov 22, 2005 | 10:14 AM
Vtec_Dude's Avatar
to me it sounds like a alternator problem.
Old Nov 22, 2005 | 10:54 AM
PRELUDE-GT35R's Avatar
I sound like you alternator and battery issue. If they are fine then ......
1) Check your alternator belt. Make sure them tight.
2) Double check all the ground wire.
Old Nov 22, 2005 | 01:00 PM
darkd1gt's Avatar
Default Re: power issues (PRELUDE-GT35R)
aight thanks i just got a new battery needed it for the stang any way, goin to get the alternator tonight. I redid my grounding kit also it has helped out a lot. Also i thought it was the jdm alternator but it was my old h23 one on there so it has 160k on it might as well get a new one.
Old Nov 22, 2005 | 05:43 PM
darkd1gt's Avatar
wow alternators are expensive, got one from autozone for like 145 bucks that is after i return my core for 105......
Old Nov 22, 2005 | 06:57 PM
All-Motor H22A's Avatar
Correct me if I'm wrong, but an alternator has like 3 coils inside. If one goes bad, it will cause those types of problem, even though your car is working and running okay.
If two goes bad, it's not enough to recharge the battery, and your car will die out.
Old Nov 22, 2005 | 07:42 PM
darkd1gt's Avatar
Default Re: power issues (All-Motor H22A)
lol interesting i didnt know that, good thing i bought a new one coming in on friday.
thanks a lot for the replys verry much appreciated
hondastrtracr
16
Jan 27, 2008 09:16 PM
97itr86
22
Jul 31, 2007 10:35 AM
EG6R
May 10, 2007 01:57 PM
92silude
Jun 14, 2005 12:11 PM
macsmurray
12
Jun 14, 2005 02:36 AM
