ABS Light
Old Nov 29, 2005 | 04:45 AM
H22a T13's Avatar
Default ABS Light
I hit a curb doing like 5 today and got stuck on the icey part. it took about 5 min of back and forth burnouts to get free. Now my abs doesnt function and the light is on. Any reason this would happen. it wasnt on after the curb. only after the attempts to get unstuck.
Old Nov 29, 2005 | 05:28 AM
mgags7's Avatar
check the sensor and its wires, and make sure that your abs ring on the axle isnt messed up or anything....
then reset the car, take the negative off the battery....if it comes back after the reset, something's shitted upon you
Old Nov 29, 2005 | 05:36 AM
The Weather Man's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">check the sensor and its wires, and make sure that your abs ring on the axle isnt messed up or anything....
then reset the car, take the negative off the battery....if it comes back after the reset, something's shitted upon you </TD></TR></TABLE>
Also could be a sevier coincidence that the relay went out.....just a thought.
Old Nov 29, 2005 | 06:06 AM
H22a T13's Avatar
Default Re: (TheKingPin)
This has happened b4. But it went away after 10 min or so. Maybe it fixed now. who knows, when i get out of school maybe it will work. Is there a chance that its a cycling curcit breaker?
Old Nov 29, 2005 | 06:08 AM
Well maybe your relay is almost dead..............
I know this happened with my lighting relay(headlights) - sometimes it would go in and out.........sometimes, it would never come on - then it eventually went out completely. Changed that relay and haven't had a problem since...........
Also - switch your headlight relay with the ABS relay and see if it stays off - they're the same relay so don't worry.
Old Nov 29, 2005 | 06:39 AM
AnthonyG2003
Guest
Posts: n/a
Yeah, They are the same relays...and if it is your relay and you dont feel like spending 55bux at honda. I have an extra one...PM me.
Old Nov 29, 2005 | 06:51 AM
H22a T13's Avatar
Default Re: (AnthonyG2003)
Well the last time it came on was when i did a burnout on ice too. maybe it has something to do with wheel spin... idk. ABS is over rated neways... jk i love it
Old Nov 29, 2005 | 07:44 AM
yeah. Just change them and let us know......
I have mine out now anyway.........
Old Nov 29, 2005 | 09:35 AM
ludesrv's Avatar
Beleive it or not but my ABS light came on after a hard *** thump (brake hard/jumped a pod hole, car went from 15-0 in no time). Turned out my abs sensor was just on the fritz for a bit, light stayed one for 2 days the nwent away. Came back on again when the brake fluid level became low, quick topup and it was ok.
Old Nov 29, 2005 | 09:44 AM
96lude_srv's Avatar
Default Re: (ludesrv)
same
TypeR0186
Nov 27, 2004 10:02 PM
Ls-Rturbo
Apr 5, 2004 02:01 PM
Rain_man
Aug 28, 2001 12:28 PM
Rain_man
Aug 28, 2001 04:32 AM
