Dead Battery Problem!!!
Old Nov 28, 2005 | 04:39 PM
smash fascism's Avatar
Default Dead Battery Problem!!!
I have a 89 prelude and just yesterday I went out to start my car and the battery was dead. I took out the alternator and had it tested only to show that it was just fine. I also tested the battery and it was fine also. any ideas? what could cause this?
Thanks, smash
Old Nov 28, 2005 | 04:47 PM
ludesrv's Avatar
Could have a ground somewhere draining the battery to the point where it can't start the car.
Old Nov 28, 2005 | 04:49 PM
hondavtecguy's Avatar
Default Re: Dead Battery Problem!!! (smash fascism)
did the engine turn over at all? and the first thing you should always do is check your fuse...i learned that the hard way. And if the engine isn't turning over it could be your starter.
Old Nov 29, 2005 | 11:36 AM
engine turns over and will run when I jump it. could it be a ground issue.
Old Nov 29, 2005 | 09:35 PM
1GPlusSH's Avatar
Default Re:
Sounds like a short to me....potentially time consuming problem.
Old Dec 3, 2005 | 02:58 PM
crxsir07's Avatar
Default Re: (smash fascism)
oh god hahah
Old Dec 3, 2005 | 07:39 PM
prelude1897's Avatar
Default Re: (crxsir07)
Try a different battery. I had the same thing happen to me before. I had a battery tested, and it tested out fine, but after running it in my car awhile, turn my car off, then try starting it again, it wouldn't start. I just got a different battery, and it worked just fine. Started up every time
Old Dec 3, 2005 | 07:58 PM
upallnite's Avatar
Just like 1897's problem, sounds like a bad cell in the battery. It will test and charge fine but the cranking amps are not high enough to start the car.
rawsx
Mar 10, 2008 10:41 AM
W O T
May 8, 2007 10:36 AM
smash fascism
Nov 29, 2005 11:57 AM
LaOstha
17
Feb 21, 2005 02:15 PM
