bolt thread specs/sizes
Old Jan 20, 2006 | 07:34 AM
shutta's Avatar
Default bolt thread specs/sizes
if anyone coudl take a look though their manual and find out what size bolts these are (length and thread size) that would be great. I lost my manual and need to get bolts I lost
I need:
bolts to hold abs sensor (front, the ones that hold the actual sensor.)
front damper fork bolt ( the bolt that pinches it to the strut )
lower ball joint castle nut
thanks. this is a repost because the thread i made before got deleted since i accidentally used all caps in the title.
Old Jan 20, 2006 | 08:33 AM
Hawkze_2.3's Avatar
Default Re: bolt thread specs/sizes (shutta)
Couldn't you just order them from http://www.hondaautomotiveparts.com??
Old Jan 20, 2006 | 09:49 AM
shutta's Avatar
I just wanted to pick them up from somewhere nearby.. not pay s hipping on 5 bolts that will come in a week. they don't tell you sizes on there either so I couldn't just look there for sizes.
Old Jan 20, 2006 | 10:15 AM
bad-monkey's Avatar
might be hard to find the exact same bolt/nuts. e.g. the flanged bolt heads on alot of hondas are not commercially available. not a big deal for some of the parts you've mentioned (though the shock fork might need a honda bolt), but make sure you get grade 8 hardware.
doesn't seem like a lot of stuff (unless you're buying spares) why not go to your local honda dealership?
Old Jan 20, 2006 | 10:33 AM
soundbomber's Avatar
Default Re: (bad-monkey)
shock fork pinch bolt = 10x1.25mm
castle nut = 14x2.0mm
abs front sensor = 8x1.25mm
the abs sensor was a bitch to find
Old Jan 20, 2006 | 10:34 AM
shutta's Avatar
i've just been busy as s*** and I have to drive 30 mins away to get to the dealer, i'm just not able to. when i origionally posted this i figured i'd be able to get it on the way home from work but, I guess i'll have to go after work today for them.
Old Jan 20, 2006 | 10:35 AM
Rosko's Avatar
Default Re: (shutta)
http://www.hondaautomotivepart...UCKLE
Look down in the list, it tells sizes.
33761 017 2 NUT, CASTLE (14MM) NO COLOR 3.67
and on a bolt like this:
31004 014 4 BOLT, FLANGE (8X14) NO COLOR 0.73
8mm flange bolt 14mm long
thread pitches should all be fine threads
alpinegroove
Nov 18, 2013 01:27 PM
raverx3m
Sep 23, 2010 06:09 PM
CivicBlack
Suspension & Brakes
Mar 4, 2010 01:27 PM
KFMRC
Honda S2000
May 18, 2006 11:08 AM
Matgallis
Aug 25, 2004 02:36 PM
