vtec problem
Old Jan 22, 2006 | 03:49 PM
Gillard82's Avatar
Default vtec problem
h22a1 throwing code:22. Beloive it is a vtec oil pressure switch. oil is full, throws this code periodically. Vtec still ingages. any ideas will be helpfull.
thanks in advance
Old Jan 22, 2006 | 03:53 PM
Skidtron89's Avatar
Default Re: vtec problem (Gillard82)
Do you have enough oil in the engine? if so then try cleaning the screen in the VTEC solenoid seal and see if that clears it up. Also try checking the wiring to the plug as it may be damaged.
Old Jan 22, 2006 | 03:56 PM
Gillard82's Avatar
Default Re: vtec problem (Skidtron89)
ok will try is asap, thanks alot
Old Jan 23, 2006 | 04:00 AM
Gillard82's Avatar
any other suggestions?
Old Jan 23, 2006 | 05:16 AM
onefastrx7turbo's Avatar
bad vtec pressure switch
Old Jan 23, 2006 | 07:05 AM
ShinobiLude's Avatar
Default Re: vtec problem (onefastrx7turbo)
Dents in the oil pan.
Old Jan 23, 2006 | 09:22 AM
Gillard82's Avatar
Default Re: vtec problem (ShinobiLude)
how much will a new pressure switch run me
Old Jan 23, 2006 | 10:33 AM
SteveoBA8's Avatar
Test the pressure switch for continuity(takes 3 seconds of your time) before you throw $ at it.
Old Jan 24, 2006 | 02:00 PM
Gillard82's Avatar
Default Re: vtec problem (SteveoBA8)
how do u do that?
Old Jan 24, 2006 | 02:56 PM
SteveoBA8's Avatar
you need a multimeter(dvom=digital volt ohm meter) my craftsmen was only $20 and it does more than i need
blueeg
Apr 25, 2006 11:16 AM
wannagofaster
Sep 4, 2004 03:25 PM
insomniac791
Jun 7, 2003 10:23 AM
insomniac791
Jun 7, 2003 08:56 AM
b18c-93
Jan 7, 2002 09:25 PM
