Adjusting Ground Controls
Old Jan 21, 2006 | 05:53 PM
snowblind7x's Avatar
Default Adjusting Ground Controls
I just got some koni yellows with eibach ground control coil overs on my car. I decided i want to raise it up a little bit so i raise the back up no problem but i can hardly budge the adjuster in the front. I guess its because trying to compress a spring by hand by turning the adjuster is pretty hard. If any one else has this combo, what do you do to adjust the ride height? Am I gonna have to get a spring compressor in order to be able to move the adjuster up?
Old Jan 21, 2006 | 06:45 PM
The Weather Man's Avatar
I thought coilovers have a little lock on them.
You use the tool to unlock the coilover and turn it to adjust the height.
Old Jan 22, 2006 | 03:26 AM
Default Re: (TheKINGPin)
yeah, i unlocked it but it's still to hard to move. It seems to be cause the spring is compressed already and trying to turn it is trying to compress the spring even more which is very hard...
Old Jan 23, 2006 | 07:25 PM
Default Re: (snowblind7x)
bump
Old Jan 23, 2006 | 08:39 PM
BA5's Avatar
BA5
What you described is what is happening. I used penetration oil, and that will usually slick them up enough that I can move them with my hands a bit further.
Otherwise, I use a pair of giant channel locks. It'll probably chew them up a bit around the outside though.
Old Jan 23, 2006 | 09:32 PM
bad-monkey's Avatar
i use my friend's spanner wrench from his progress coilovers.
Old Jan 23, 2006 | 09:38 PM
skrewdlude's Avatar
Default Re: (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">i use my friend's spanner wrench from his progress coilovers. </TD></TR></TABLE>
I do this with a little oil, and they turn no problem. You can pick up a set of spanner wrenches cheap from any "tuner" shop. If you don't have any in the area Pegasus has them for 9 bux
Old Jan 24, 2006 | 06:28 AM
shutta's Avatar
there shouldn't be that much compression from the spring once you jack up the car. one my buddies car when you jack it up, you get about a 4"+ gap from the top of spring to the bumpstop or whatever, if you can't find a spanner, use a flathead screwdriver and a hammer and tap the rings, opposite ways at the same time, you might need another hand but it shoudl work. that's what I did.
Ef4doorwagon
Dec 16, 2015 12:54 PM
Bustin_Hatch305
Suspension & Brakes
22
Sep 5, 2012 03:28 AM
Integra187
Mar 27, 2004 02:14 PM
sjteg
Dec 27, 2003 09:16 PM
B18Redline
Aug 28, 2003 08:00 PM
