intake problem. help?
Old Jan 16, 2006 | 07:21 PM
lude-tec's Avatar
Default intake problem. help?
i just bought an aem short ram intake for my 1993 honda prelude vtec. the intake came but it only has one tiny tube for one hose and none for the vaccum lines. im just wondering what other people did with their intakes. any help would be appreciated thanks.
Old Jan 16, 2006 | 07:27 PM
BB6racer's Avatar
i'm confused. there nozzle on the intake right before the throttle body. then there is a vacuum line that goes from that to the valve cover. i think there is also a vacuum line that goes to the stock air box, but i just plugged it with a small screw.
Old Jan 16, 2006 | 07:29 PM
CivicSiDriver02's Avatar
Default Re: (BB6racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6racer &raquo;</TD></TR><TR><TD CLASS="quote">i'm confused. there nozzle on the intake right before the throttle body. then there is a vacuum line that goes from that to the valve cover. i think there is also a vacuum line that goes to the stock air box, but i just plugged it with a small screw.</TD></TR></TABLE>
ditto
Old Jan 16, 2006 | 07:40 PM
ed_1's Avatar
Default Re: (CivicSiDriver02)
Well that tube just hooks up to the valve cover, and they should've gave you a little nipple to put over the and i think is the fast idle valve. If you do put it, the car will rev whenever it wants to.
Old Jan 16, 2006 | 09:09 PM
lude-tec's Avatar
thanks for the replys, i know the tube that hooks up to the valve cover. what im curuius about is that my sister's intake has two tiny tube the bigger one is for the valve cover and the other one is for the vacume line, i think. its the one that connects to a small round metal dont know what its called. its about the same size as a bottle cap and say "up" on top. on my stock intake its connected to the plastic pipe, but on the aem theres only one tube. and that for the valve cover.
Old Jan 16, 2006 | 09:11 PM
InvaderTrax's Avatar
Default Re: (ed_1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ed_1 &raquo;</TD></TR><TR><TD CLASS="quote">Well that tube just hooks up to the valve cover, and they should've gave you a little nipple to put over the and i think is the fast idle valve. If you do put it, the car will rev whenever it wants to. </TD></TR></TABLE>
...wha? Anyway, you can just disconnect the hose from the tiny line and let it breathe into the open. Won't hurt anything. Wouldn't suggest plugging it with a screw though. It's there for a reason
Old Jan 16, 2006 | 09:26 PM
lude-tec's Avatar
yea but isnt it pluged on the filter for a reason? how can that not hurt anything if its taking in dust.
Old Jan 16, 2006 | 09:37 PM
Well, for one, it's a very tiny hole. You can't get much dust through there. Also, air really isn't that dirty (in most places in the world. If you've got lots of sand or heavy pollution, get a filter). And I'm not real sure if that thing breathes in or pushes out air
Old Jan 17, 2006 | 09:40 PM
lude-tec's Avatar
ok so the only thing that im pluggin back in is the valve cover hose?
Old Jan 17, 2006 | 09:44 PM
jaybees's Avatar
i plugged mine but I got a wierd idle when my AC was on so I removed the plug and left it open air. No problems since. I believe its the line for the fast idle valve.
Old Jan 17, 2006 | 09:55 PM
ed_1's Avatar
Default Re: (jaybees)
Well i think the hose going to the valve cover is so oil could go into the intake, so that if dirt does get into there the oil will trap it.
Old Jan 18, 2006 | 12:24 PM
lude-tec's Avatar
i forgot to mention theres a small round sponge inluded in the kit. where does it go?
Old Jan 18, 2006 | 07:25 PM
Sabbotage's Avatar
Default Re: (lude-tec)
didnt it come with directions? I've owned 3 AEM intakes and they all had directions with them. Just a thought.
Old Jan 18, 2006 | 09:19 PM
ed_1's Avatar
Default Re: (Sabbotage)
Well they should've gave you two options one to put that sponge on the iac valve, the one that the original intake went to. And it should've gave you a nipple incase you didn't want to put the little sponge in.
wasanissanFL
Oct 4, 2015 03:11 PM
kornkid21792
Jun 19, 2009 10:57 PM
DOHC Kid
19
May 17, 2008 05:30 PM
sony224422
Jul 21, 2006 02:43 PM
sldcivic
Jan 18, 2006 09:14 AM
