RPM problem
Old Jan 15, 2006 | 01:44 PM
Lubriel609's Avatar
Default RPM problem
heyguys, i'm having a bit of a technical problem with my 92 prelude. When i rev it, the RPM continues to go up slightly, after i've released the gas. Does any one have any idea what the problem might be????
Old Jan 15, 2006 | 01:52 PM
The Weather Man's Avatar
Maybe your throttle is sticking.
Try lubing the cable with some WD-40.....
Old Jan 15, 2006 | 03:29 PM
Fongman's Avatar
Default Re: RPM problem (PRelude2Tragedy)
check your throttle cable?
Old Jan 15, 2006 | 03:31 PM
BDRphaSe2's Avatar
Default Re: RPM problem (Fongman)
clean the door on your throttlebody
Old Jan 18, 2006 | 02:53 PM
Lubriel609's Avatar
Default Re: RPM problem (BDRphaSe2)
how do i clean the door
Old Jan 18, 2006 | 03:56 PM
mgags7's Avatar
spray it with cleaner and wipe it clean
or maybe you can use the throttle body attachment on your house vacuum....that should do well...
therichisgood
May 3, 2014 09:36 AM
kornfox
Sep 7, 2010 12:24 PM
88si
Feb 28, 2009 05:27 PM
raidacaipo
Oct 12, 2008 06:42 PM
usdmcrx
Feb 20, 2003 01:12 PM
