oil on spark plug threads?
Old Jan 18, 2006 | 05:05 PM
BB6racer's Avatar
Default oil on spark plug threads?
i did a search but i didn't find enough to satisfy my curiosity. i was checking my spark plugs today and i noticed that after i removed the plugs the threads were covered in oil. the wires and the socket i used to remove them were clean, and so was the spark electrode of the plug (but i guess detonation would burn any oil that would have been there). i just though it was wierd that the spark plug threads were to only thing covered in oil. i will be replacing the O-rings tomorrow, but does anyone know why the oil is only on the threads?
Old Jan 18, 2006 | 05:06 PM
93h22a1vtec's Avatar
Default Re: oil on spark plug threads? (BB6racer)
get valve cover gasket, comes with the 4 round gaskets that seal off the spark plug chamber with the head
get valve cover gasket, comes with the 4 round gaskets that seal off the spark plug chamber with the head....not to big of a deal
Old Jan 18, 2006 | 05:16 PM
UNLTD's Avatar
Default Re: oil on spark plug threads? (93h22a1vtec)
The same thing happen to me when I was changing my spark plugs on my 98 prelude. Someone told me it could be worn internals or/and shot cylinder walls. Also Piston rings can we out too. Either way it's not good, check the problem out.
Old Jan 18, 2006 | 05:19 PM
iLude's Avatar
It's probably just your valve cover gasket like someone already said. I just did one on my girl's DSM who had the same issue, and it solved the problem.
Old Jan 18, 2006 | 05:20 PM
CGags13's Avatar
Default Re: oil on spark plug threads? (UNLTD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNLTD &raquo;</TD></TR><TR><TD CLASS="quote">The same thing happen to me when I was changing my spark plugs on my 98 prelude. Someone told me it could be worn internals or/and shot cylinder walls. Also Piston rings can we out too. Either way it's not good, check the problem out.</TD></TR></TABLE>
oh really??? did the crank bearings go..oh ok the sleeves walked...damn
dont spew rhetoric that "someone" told you
my dad told me that he can fly and outrun a cheetah
bb6racer-its the 4 gaskets for around the plug holes
Modified by CGags13 at 6:38 PM 1/18/2006
qhiggy
10
Mar 3, 2015 08:49 PM
1998_4dr_gsr
Apr 13, 2011 09:02 AM
VTEC_Du_Ma_Mai
Sep 6, 2008 11:08 AM
aWeimaraner
Jan 25, 2008 10:52 AM
matryx
Dec 15, 2007 01:18 PM
