replacing driver side axle
Old Jan 18, 2006 | 03:10 PM
staticrex's Avatar
Default replacing driver side axle
Is this a really hard job? Could I get it done in the front yard with hand tools and jacks?
I will also be replacing the bushings, boots, washers, nuts and all that good stuff while I am in there.
How bad could I actually screw up?
Old Jan 18, 2006 | 03:54 PM
CGags13's Avatar
Default Re: replacing driver side axle (staticrex)
with the right tools and general mechanical knowledge youll be fine..check this out if youre unsure how to do it: https://honda-tech.com/zerothread?id=382416
Old Jan 18, 2006 | 04:09 PM
BB6racer's Avatar
only thing you could really messup is your alignment. just make sure evrything goes back in the right place and every bolt is torqued to spec.
lowtegsr
Feb 1, 2008 07:18 AM
dynamo
13
Nov 14, 2005 08:22 PM
91zSi
30
Aug 4, 2005 04:09 PM
clean
Jun 17, 2001 06:33 PM
