quick question!
Old Jan 15, 2006 | 10:29 PM
lude-tec's Avatar
Default quick question!
hi i just have a quick question? i have a h22a1, and its trowing codes i for got the number but its about my egr. will that disable vtec or can i still engage vtec. and one more thing which do you guys preffer should i install an h22a or just overhaul my h22a1 it has 156000 miles on it and some leak. thanks
Old Jan 15, 2006 | 10:31 PM
BB6racer's Avatar
vtec will be fine, i have the same egr problem. as for the motor, i would say keep your current motor as long as possible, but when it does finally die on you, go with the h22a.
Old Jan 15, 2006 | 10:54 PM
lude-tec's Avatar
so you dont recomend doin an overhaul on the engine?
Old Jan 16, 2006 | 01:34 AM
y0whuddupb's Avatar
Default Re: (lude-tec)
EGR stuff i dont kno about. but i can definitely relate to you with the H22A1 swapping thing. i got 208k and sick oil leaks. still pulls hard though! but i know its gonna go out soon so im saving now! just start saving for the H22A from this point on. so atleast u know if the motor dies out u already have the next one ready to drop in! good luck with the EGR thing though sorry i was no help.
Old Jan 16, 2006 | 06:06 AM
fzr's Avatar
fzr
Default Re: (yO_wHuDdUp_B)
I had the EGR code (12). I removed the valve (it's just behind the head, easy enough to get to but you'll need a thin socket extension to get the two nuts off) and cleaned it out with carb cleaner as suggested elsewhere (have a search, there's lots of stuff about). It was full of black gunk, now it's nice and clean and no codes
My EGR valve had no gasket on it and I couldn't find one easily, so I just used some Holts Instant Gasket which seemed to work fine, though might have been unnecessary.
Sad thing was, the very next day my clutch master cylinder died!
92_civic_lx
Oct 12, 2008 10:33 AM
ShinobiLude
Aug 4, 2005 07:51 AM
XSuperStreetGTX
May 16, 2004 08:45 PM
RAK
Apr 6, 2004 05:15 PM
