tech head get in here, code 9 with odb1 ecu, odb2 ecu no code
Old Jan 15, 2006 | 04:30 PM
lakerschamp2000's Avatar
Default tech head get in here, code 9 with odb1 ecu, odb2 ecu no code
when i am running on odb2 ecu, there's no code.
when i plug odb1 ecu, it would give me a code 9 which is No 1 cyclinder position.
anyone knows what is going here?
maybe timing is off at tdc?
Old Jan 15, 2006 | 07:23 PM
Rosko's Avatar
Default Re: tech head get in here, code 9 with odb1 ecu, odb2 ecu no code (lakerschamp2000)
arent the crank position sensors in different places on obd1 vs obd2? I think obd1 is in the distributor and obd2 is on the crank by the oil pump. This might affect some wiring or something.
Old Jan 15, 2006 | 07:56 PM
mrlover's Avatar
Default Re: tech head get in here, code 9 with odb1 ecu, odb2 ecu no code (Rosko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">arent the crank position sensors in different places on obd1 vs obd2? I think obd1 is in the distributor and obd2 is on the crank by the oil pump. This might affect some wiring or something. </TD></TR></TABLE>
ditto, you might be rite, but in this case he is getting code 9
Old Jan 15, 2006 | 09:51 PM
bigz187's Avatar
Default Re: tech head get in here, code 9 with odb1 ecu, odb2 ecu no code (mrlover)
yea its in the dizzy with OBD-1...I had the same fuc*in problem when I ran my p72....we swapped out my dizzy with an 00 lude dizzy and bam...no CEL.
LDS
Jan 6, 2008 07:03 AM
b20izzle
Oct 26, 2005 07:53 PM
cheeks97R
Apr 17, 2005 09:34 AM
AzNpRiD3
May 14, 2004 06:05 PM
Javier23
Mar 31, 2004 01:23 PM
