o2 Sensor question
Old Apr 6, 2006 | 12:04 PM
RyosukeFC3s's Avatar
Default o2 Sensor question
Hey, I got a 99 SH, and I just got a test pipe for it. Will I need an O2 simulator to run it correctly, or will it run just fine the way it is? Thanks.
Old Apr 6, 2006 | 12:07 PM
prelude1897's Avatar
Default Re: o2 Sensor question (RyosukeFC3s)
I would put an 02 sensor in there, cause if you don't, your check engine light will come on
Old Apr 6, 2006 | 12:15 PM
Default Re: o2 Sensor question (prelude1897)
alright, thanks. Know where I can get one? and about how much would it be?
Old Apr 6, 2006 | 12:45 PM
577HondaPrelude's Avatar
it will run just fine, but your check engine light will come on with a code for cat. inefficiency. This code does not put your car in limp mode, thus it still runs fine. If you want the light to stay off then you need to get a "smart" 02 sim. The dumb resistor, or oscillator o2 sims will not work on our cars.
I know the ECG sim works, and you can get one here:
http://www.importparts.com/sho...=2770
Old Apr 12, 2006 | 02:13 PM
cdk001's Avatar
Default Re: o2 Sensor question (apeng09)
I don't get it.... What do you do with a test pipe and why would you use this smart 02 in place of the secondary 02 sensor.. .. is the test pipe replacing the cat.
Old Apr 12, 2006 | 04:01 PM
BB6racer's Avatar
yes a test pipe basically replaces the cat, so you have less exhaust flow restriction. i personally would never do this to a street car, because of all the negative emissions stuff and non-cat cars smell like rotten fish IMO. you could just buy a bolt to fill the hole in the test pipe too ya know.
95acuraintegra
Jan 8, 2009 04:54 PM
avotegra
Nov 25, 2008 04:23 PM
rebuiltSI
Jun 29, 2007 05:56 AM
sickofitall1113
Jun 9, 2005 12:18 PM
Dai_Ca_Vietnam_H22a4
May 21, 2005 08:42 PM
