Could this problem be fixed by the Ignition switch recalls..5th gen ignition problem
On my 97 sh about every third time I try and start it I turn the key, the dash key light comes on but no start. I usually have to remove and re-insert the key to get it to start.
Re: Could this problem be fixed by the Ignition switch recalls..5th gen ignition problem (justint)
It sounds more than likely that your ignition switch is at fault, book it into the dealers it's all free of charge anyway and will eliminate that as a problem if not cure it. The recall was done on safety grounds, because the worst thing that can happen is the car cutting out at a critical time like when overtaking.
Re: Could this problem be fixed by the Ignition switch recalls..5th gen ignition problem (britishlud
well it turns out that the ignition switch recall was done last year..so either I got a bad switch or it is something else
any ideas?
any ideas?
its your immobilizer system going out. mine does it too. mostly when its hot.
having the same problem, wish it wasn't almost SUNDAY.
<hoping the dealer will give me a new switch while at the same time praying its not the immobilizer system?**
Location: With my POS D15B2, Whereever whenever, United States
it is the immobilizer
i get it every now and then to
it sucks
it sucks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda »</TD></TR><TR><TD CLASS="quote">it is the immobilizer
i get it every now and then to</TD></TR></TABLE>
I take it there isn't a cheap fix to this problem?
badfish2282
05-15-2009 08:45 PM
