Starting Problem
Old Aug 8, 2006 | 02:13 AM
bengal's Avatar
Default Starting Problem
my 1990 prelude si at times is hard to start in hot weather. It turns over but won't start, after several minutes it will finally start. Seems to happen when gas tank is full or near full. Releasing the gas cap helps it to start sooner.
Old Aug 8, 2006 | 05:53 AM
Speedra500's Avatar
Default Re: Starting Problem (bengal)
bad fuel pump possibly? I would remove the fuel line to the fuel rail and verify that it is getting decent fuel flow when you turn on the ignition
Old Aug 8, 2006 | 11:27 AM
nailbender42's Avatar
i would check the fuel pressure at the fuel rail. a new in tank fuel pump runs about 100 bucks. good luck
Old Aug 9, 2006 | 08:50 AM
y0whuddupb's Avatar
Default Re: Starting Problem (nailbender42)
check the main relay. usually when a main relay goes bad. it is usually hard to start on a hot day.
biggs88
Sep 23, 2012 01:31 AM
allmotor2.1
Nov 24, 2007 04:52 AM
cybercg
Sep 10, 2006 05:20 PM
91d15bvtec
Jun 29, 2005 05:08 PM
Magick211
Oct 30, 2004 10:28 PM
