Is this a good combo?
Old Aug 11, 2006 | 10:07 PM
jdm00civicex's Avatar
Default Is this a good combo?
For the price is this a good clutch/flywheel combo, if not can someone recommend a good clutch/flywheel combo off ebay for under $350? Thank You
http://cgi.ebay.com/ebaymotors...QrdZ1
Old Aug 11, 2006 | 11:10 PM
lude1888's Avatar
Default Re: Is this a good combo? (jdm00civicex)
Possibly depending on why you think you need a puck clutch.
Old Aug 11, 2006 | 11:45 PM
so i should not get a puck clutch? whats the difference between the regualr disc and the puck clutches?
Old Aug 12, 2006 | 12:00 AM
InvaderTrax's Avatar
I don't have experience with the stage 3, but I have their stage 1 and although it was good in the beginning, I don't think it's gonna last as long as the stock one
Old Aug 12, 2006 | 12:08 AM
russlan44's Avatar
Default Re: (InvaderTrax)
i was looking at that the other day and thinking about it for a little what u guys think is it good any advise, i have their stage one its preatty sucki i dont know sometimes slips when race but its stage one i dont know so plz give some advise tx
Old Aug 12, 2006 | 01:31 AM
94Vtecluder's Avatar
Default Re: (russlan44)
To put it simply you don't need a puck clutch. Unless ur engine is seriously modded or u plan too. Basically puck clutches engage a lot faster and more harshly. You like the rest of the 90% of us don't need a puck clutch.
Old Aug 12, 2006 | 01:39 AM
russlan44's Avatar
Default Re: (94Vtecluder)
well having basic mods like i/h/e, APEXi VAFC 2, Skunk2 cams stage 2. thats about it the upgrades ill have on it what do u suggest?
Old Aug 12, 2006 | 01:41 AM
russlan44's Avatar
also have Skunk2 cam gears but not sure ill get thouse on cuz ill have to take out the side cover and if cops see them they will write u up for boost up timing and send u too ref smog check and inspection
Old Aug 12, 2006 | 08:57 AM
so for under $350 what kinda clutch/flywheel combo do you guys recommend????
Old Aug 12, 2006 | 09:02 AM
is this any good?
Old Aug 12, 2006 | 09:20 AM
98vtec's Avatar
moderator emeritus
Default Re: (jdm00civicex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm00civicex &raquo;</TD></TR><TR><TD CLASS="quote">is this any good?
http://cgi.ebay.com/ebaymotors...QrdZ1</TD></TR></TABLE>
yes, thats a good combo. That should be all the grab you need unless you plan on going turbo or a fully built motor in the next couple years.
Old Aug 12, 2006 | 09:33 AM
jaxx4k's Avatar
Default Re: (98vtec)
im runnin ACT HD pressure plate /centerforce 6 puck spung/10lb center force flywheel. stiffer pedal n grip nice.. i cant complain...
Old Aug 12, 2006 | 02:03 PM
lude1888's Avatar
Yes I agree that this will be o.k depending on how much power you are making or planning on soon, but If you are running a little more hp I personally found a stage II clutchmasters combo with fidanza light weight and It is awesome which I believe ebay still sells.
2000HondaEm1
10
Aug 8, 2009 11:34 AM
DonReggeaton
18
Jun 10, 2009 03:11 PM
Corruption
Feb 2, 2007 08:29 AM
BulliztyK
Jun 5, 2003 09:17 PM
Ben Huynh
Jun 17, 2001 01:16 PM
