Weird brake problem 2
Old Aug 10, 2006 | 06:47 PM
Prelude4ws's Avatar
Default Weird brake problem 2
Hi everyone,
Ever since I got this car a couple months ago, it had a brake problem and it seems to be getting worse.
The brake seems to work fine when I'm driving or if the rpms are higher than 2000. At a stop or whenever the rpm is below 1500, the brake pedal will completly sink to the floor and then finally work.
Im not sure how the brake booster works but Im guessing thats the problem.
My friends tell me its a simple air in the brake lines but I've had that problem before and I've already bleed the system.
Can anybody give me a heads up.
Thanks
Old Aug 10, 2006 | 07:10 PM
soundbomber's Avatar
Default Re: Weird brake problem 2 (Prelude4ws)
sounds like your master cylinder is dying, lemme know if you need another one, i got one for cheap
Old Aug 10, 2006 | 07:26 PM
InvaderTrax's Avatar
It's definitely the master cylinder. A bad booster would make your pedal really stiff, and air in the lines would make your brakes spongy. Sinking pedal is a leaking cup seal in the MC, which is replaced as a whole unit instead of just replacing the seal (the MC isn't easily serviceable so it's cheaper and easier to replace the whole thing)
Old Aug 10, 2006 | 10:29 PM
Prelude4ws's Avatar
Thanks for the fast replies,
Can't do anything without you guys.
fantasyboi_k
Feb 15, 2014 12:45 PM
Civic-Kids
Nov 24, 2009 05:07 AM
blkteggy
Mar 13, 2008 10:14 AM
superhatchbackbros
Jun 7, 2007 09:58 PM
tilt
Mar 11, 2003 08:52 PM
