starter ? and trans ?
Old Aug 10, 2006 | 07:42 PM
xxmastermindxx's Avatar
Default starter ? and trans ?
so i took apart the starter right, or at least tried. you know how there are two long skinny bolts holding the actual motor part to the housing? i tried taking them out, and i thought i was, but the ends snapped off in the housing. anything i can do other than getting a new starter?
as for the trans, i just finished putting everything back together (motor swap, H23 to H23, old one blew). i thought i did a great job of keeping everything organized, but i have a bracket mounted to trans with nothing on it. its directly to the left of the slave cylinder. i think its just a wire/hose harness bracket, but i wanna be sure.
thanks honda freaks
Old Aug 11, 2006 | 09:13 AM
prelittlelude's Avatar
Default Re: starter ? and trans ? (xxmastermindxx)
well depending on what you broke on the started you may just need a new one. and the bracket to the left of the slave cylinder is for the batery cable holder
Old Aug 11, 2006 | 04:58 PM
TheWalrus's Avatar
try using an ez out on the bolts, but it probly wont work. and the bracket is for the upper radiator hose
Choppacity
Aug 21, 2014 03:56 PM
hardcore97
Jan 30, 2013 07:55 AM
AK94GSR
Sep 14, 2010 08:12 AM
bayoufrogg
Oct 30, 2006 07:41 PM
