help on the h23
Old Aug 10, 2006 | 04:23 PM
lucyh23's Avatar
Default help on the h23
what is the difference from the h23a and h23a1. Would someone tell me more about what motors went in what year of car and also tell me more about the jdm motors. hp,torque etc.... just give me some info. i would like to learn all i can about h series motors
thanks
lucyh23
Old Aug 10, 2006 | 04:26 PM
InvaderTrax's Avatar
H23A1 - USDM DOHC nonVTEC
H23A - JDM DOHC VTEC (rare)
Old Aug 10, 2006 | 04:31 PM
lucyh23's Avatar
Default Re: (InvaderTrax)
thanks a bunch man
well you tell me more about the h series motors though. Like what year car had what motor in it and how much hp they had . i wunna know about the 92 all the way up to 01 preludes.thanks lucyh23
Old Aug 10, 2006 | 05:02 PM
lude1888's Avatar
Default Re: (lucyh23)
Not true because I have a JDM h23a non-vtec, but there is a h23a vtec model (blue top).
Old Aug 10, 2006 | 05:17 PM
The H23A1 was available in the 92-96 USDM Prelude SI. 160hp and 156tq. The JDM H23A VTEC was available in the Accord SiR wagon. 200hp and some high amount of tq (180 or something)
Old Aug 10, 2006 | 05:42 PM
twistedbydezign's Avatar
Default Re: (lude1888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">The H23A1 was available in the 92-96 USDM Prelude SI. 160hp and 156tq. The JDM H23A VTEC was available in the Accord SiR wagon. 200hp and some high amount of tq (180 or something)</TD></TR></TABLE>
riiiight, i cant wait for when my stock h23vtec is done ill have 180tq....try 163...all h specs and which cars it came in can be found here https://honda-tech.com/zerothread?id=641555 , everything else you need to know can be found in the F.A.Q. stickied at the top
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude1888 &raquo;</TD></TR><TR><TD CLASS="quote">Not true because I have a JDM h23a non-vtec, but there is a h23a vtec model (blue top).</TD></TR></TABLE>
until we see your engine stamp you are just a big fat liar, unless you are talking about an f22b....
Old Aug 10, 2006 | 11:05 PM
lude1888's Avatar
Default Re: (twistedbydezign)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign &raquo;</TD></TR><TR><TD CLASS="quote">until we see your engine stamp you are just a big fat liar, unless you are talking about an f22b....</TD></TR></TABLE>
I don't understand it either, but I bought it as a short block and couldn't figure out why it wasn't the vtec model.
Old Aug 10, 2006 | 11:27 PM
lude1888's Avatar
Also I found others with the same, but could someone please explain where the h23a non-vtec comes from?
Old Aug 11, 2006 | 05:53 AM
92hondalude's Avatar
must be the h23a block with the h23a1 head on it.... why someone would do that i dont know...
Old Aug 11, 2006 | 07:57 AM
prelittlelude's Avatar
was this motor oem? what contry is this? and where did you get the car? motor history tell us more.. has their been a swap done?
Old Aug 11, 2006 | 09:08 AM
lude1888's Avatar
Default Re: (prelittlelude)
myself as well as others have bought these engines jdm from supliers such as hmotors and sunrise which they get in every once in a while. And yes these are swaps, but is there anyone who has info on these engines?
Old Aug 11, 2006 | 09:11 AM
if you were able to do a compression test that might tell us soemthing about the pistons, if i could find some stock h23a1 compression numbers to compare them to..
i would also be very interested in the bottom end, if you pulled the oil pan off and were able to somehow measure the mains if you pulled a cap.
Old Aug 11, 2006 | 09:24 AM
lude1888's Avatar
Alright check it out I found that there is a h23a non-vtec when talking with someone who really know his stuff and found a website:
http://www.jdmenginescorp.com/...age=3
Turns out it comes in the 96+ preludes in Japan, but the question is whether the block is a closed or open deck compared to the h23a1.
Old Aug 11, 2006 | 10:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude1888 &raquo;</TD></TR><TR><TD CLASS="quote">Alright check it out I found that there is a h23a non-vtec when talking with someone who really know his stuff and found a website:
Turns out it comes in the 96+ preludes in Japan, but the question is whether the block is a closed or open deck compared to the h23a1.</TD></TR></TABLE>
well it probably closed deck, they didn't go open deck until 97. it would be interesting to know all the specs on your motor..
lil_mowgli
Jun 8, 2009 06:31 PM
sohc prelude
Apr 14, 2006 09:45 AM
Ziggymidget5
Jan 12, 2006 12:07 PM
robbc18
Aug 8, 2005 07:23 PM
d16vteceg
Jul 7, 2005 10:34 PM
