compression test question?
Old Aug 13, 2006 | 07:54 AM
ge_itr's Avatar
Default compression test question?
i just did a compression test. valve #4 was 190. the rest 3,2,1 just went over board, i mean isn't there suppose to be a max per clynder. on valves 3,2,1 the more you crank the higher it gets. it don't stop. goes up to 290 and around to zero. am i not testing it right, cause # 4 was fine. oh, what i did was unlpugged the primary from the distributer and open the throttles plate. did i forget something? did the same thing to my brothers B18 and everything went fine.
Old Aug 13, 2006 | 08:14 AM
vinuneuro's Avatar
Default Re: compression test question? (ge_itr)
That's because you're getting fuel in the cylinders because you didn't pull the ecu fuse.
watsvtecEK
Dec 12, 2005 07:28 AM
Sport_Injected
Aug 25, 2004 09:21 PM
11psiTurboSI
Apr 13, 2004 11:26 PM
t0p_sh0tta
Feb 3, 2003 01:33 PM
