H22 CEL help
Old Aug 12, 2006 | 04:17 PM
H22Ej2's Avatar
Default H22 CEL help
Heres the story
Completed the swap and have had this code
Ran like crap basically hesitant at low RPM and have no torque
then today went in a store came out and the light went off and then torques back
Now it comes on some times but not all the time?
throwing code 10....Intake Air TEMP
CHeck connection at ECU and it's fine
Is this what's making me have no TORQUE?
Old Aug 12, 2006 | 07:58 PM
JasonST's Avatar
Default Re: H22 CEL help (H22Ej2)
Sounds like it's intermittent, check the connector, unplug it and see if it needs cleaning, also, check the wires to make sure they're in their nice and tight. I personally don't know much about a code 10 problem, try searching for it, I'm sure u'll come up with lotsa info, Bump!
Old Aug 13, 2006 | 06:30 AM
Duane_in_Japan's Avatar
Default Re: H22 CEL help (JasonST)
I want to think that AIT and ECT (TW) have nothing to do with fuel delivery after the computer goes into closed loop (fully warmed up). But if you turn off the engine and recycle the key to start the engine then a bad sensor may act up.
SO at the start of your day, you start the car, it gets fully warmed up, do you have the problem or is it on a restart later that day. Are you loosing torq during the initial run now or on subsequent runs.
I think you need a shop with a scanner to look at parameters for you when the problem is acting up. Could another plug that looks like the air intake temp connector have been swapped accidently. Maybe the wire harness was damaged during the conversion??? and the AIT wire is making contact intermittently, this is very logical. Do a harness wiggle test.
Old Aug 13, 2006 | 09:22 AM
v4lu3s's Avatar
RTFM
what car is it swapped into? I have seen accords with the IAT plugged into nothing while the ppower steering sensor plug is in the manifold.
Old Aug 13, 2006 | 10:01 AM
H22Ej2's Avatar
Default Re: (v4lu3s)
took out the sensor and it looked horrible like corrosion and stuff that almost looked like solder was on it(don't know what it was) ordered a new sensor and will keep you posted to see if it does the trick.
When i first start up the car i drive it then it's fine but once it barely starts warming up it has no torque, but the top end is fine. But the CEL light is always on
Swapped into a 93 DX coupe
THE IAT has to deal with proper AIR/FUEL Mixture
Old Aug 14, 2006 | 08:59 AM
H22Ej2's Avatar
Default Re: (H22Ej2)
issue seems fine now replaced sensor today and went out for a test drive light stayed off.....i'm going to wait till it cools down all the way and go out for another test drive.
Old Aug 14, 2006 | 04:56 PM
H22Ej2's Avatar
went out with new SENSOR AND BAM!! fixed
Old Aug 14, 2006 | 06:01 PM
JasonST's Avatar
Congratz!
Manifest113
Oct 24, 2014 02:03 PM
az90civic
Sep 7, 2007 08:05 AM
bstaralways
Sep 4, 2007 02:51 PM
blu3g
12
Feb 14, 2007 12:47 PM
wadafa
11
Oct 3, 2002 03:49 PM
