Front end Shaking! please help (UNDER LOAD ONLY)
Old Aug 8, 2006 | 08:40 AM
Boudreau's Avatar
Default Front end Shaking! please help (UNDER LOAD ONLY)
ok so i got my front end clicking taken care of...... but now i have this problem (had it the whole time just doing 1 thing at a time)
so at about 45-50mph+ my front end of my car starts to shake pretty violently * ONLY UNDER LOAD *
it only happens when im at about 50% or higher acceleration. and it doesnt do it at all in 1st or 2nd gear.. only 3-5th.
i started off eliminating problems in this order....
checked all motor mounts
checked every bolt/nut i could find on the front end (crossmembers, brackets, everything)
bought new suspension (Kyb-Agx fully adjustables with Skunk2 Coilovers)
bought new tires (Eagle RS-a)
2 new axles
and again checked to see if everything is tight.
now im just lost, i cant figure out waht it is. i searched this topic but it ended up being peoples axles... well im sure its not taht i just put 2 new ones in within a week from today.
if anyone has a better idea of what it is let me know :D thanks in advanced.
Dan
Old Aug 8, 2006 | 08:43 AM
94vtecmn's Avatar
Default Re: Front end Shaking! please help (Boudreau)
Clutch?
Old Aug 8, 2006 | 11:32 AM
nailbender42's Avatar
you might wanna check the balance on the tires. even though they are new, it is possible you may have thrown a weight, or they may have not been properly balanced. usually when you buy tires, they come with a lifetime balance and rotation...so really, this is a cheap attempt to fix an aggravating problem. one other thing you might check... see if your wheels are running true....could be wheel run out which could cause a vibration. good luck !
Old Aug 8, 2006 | 01:02 PM
blueBB4lude's Avatar
Default Re: Front end Shaking! please help (nailbender42)
id definetly check the tire balance, and wheel alignment. Another potential canidate is the balance shafts, is the belt properly aligned tensioned
Old Aug 8, 2006 | 02:02 PM
98vtec's Avatar
moderator emeritus
Default Re: Front end Shaking! please help (blueBB4lude)
alignment
or
Inner CV axles
Old Aug 8, 2006 | 11:53 PM
Boudreau's Avatar
balance on tires = shaking all the time, it only shake's when i am accelerating......... balanced tires are out of the question i think
Old Aug 15, 2006 | 06:08 AM
Boudreau's Avatar
well i still cant figure this out, so i went and orderd 2 NEW axles again today i hope this is the only problem.....
bump
Old Aug 15, 2006 | 09:25 AM
v4lu3s's Avatar
RTFM
symptoms are classic for badd inner cv joints.
Old Aug 15, 2006 | 10:00 AM
machine4321's Avatar
yup . what he siad
Old Aug 15, 2006 | 02:48 PM
92hondalude's Avatar
Default Re: (machine4321)
def inner cv joint most likely the passanger side
93dabeast
Suspension & Brakes
Mar 14, 2007 09:44 AM
93dabeast
Mar 14, 2007 04:11 AM
r2d97
Aug 4, 2005 09:38 AM
