oxygen sensor heater problem
Old Nov 10, 2006 | 02:20 PM
ge_itr's Avatar
Default oxygen sensor heater problem
i got code 41 which is the oxygen sensor heater. i'm not sure which sensor it is and where it's located. can any one help me on this?
Old Nov 10, 2006 | 02:34 PM
Hawkze_2.3's Avatar
Default Re: oxygen sensor heater problem (ge_itr)
Uhh...what year is your car? Need to know if it's OBD1 or OBD2...
Old Nov 11, 2006 | 10:21 AM
ge_itr's Avatar
Default Re: oxygen sensor heater problem (Hawkze_2.3)
it's a 4th gen.
will it effect how my car run though?
Old Nov 11, 2006 | 10:53 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Uhh...what year is your car? Need to know if it's OBD1 or OBD2...</TD></TR></TABLE>
Old Nov 11, 2006 | 03:08 PM
ge_itr's Avatar
94' to be exact.
Old Nov 11, 2006 | 04:40 PM
Hawkze_2.3's Avatar
OK so 94 is OBD1. You only have 1 O2 sensor and it's located right before the flex pipe on the header (just behind the oil pan under the car). I would just get a new Bosch sensor for $50-60.
Old Nov 12, 2006 | 04:50 AM
Duane_in_Japan's Avatar
Sorry, I dont have every car to memory, is this a three wire sensor, only buy OEM, get a repair manual from the library and see how to test the heater portion, inspect the harness for chaffing and maybe the heater wire is rubbed through to the chassis or the bracket under the intake manifold. Your car should run fine, it is only meant to heat up the O2 sensor quicker than the exhaust can heat it up so your car can stop polluting sooner.
Old Nov 12, 2006 | 09:43 AM
M2B4's Avatar
Default Re: oxygen sensor heater problem (Duane_in_Japan)
o/t but woudlnt it not being able to heat up soon enough have ne thing to deal with not having correct a/f? or am i just shooting in left field
Old Nov 12, 2006 | 10:03 AM
WhiteBB2's Avatar
Default Re: oxygen sensor heater problem (M2B4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">I would just get a new Bosch sensor for $50-60.</TD></TR></TABLE>
I bought a new NGK o2 sensor...Replaced my old one and am still throwing this code. But it only happens when I try to "get on" the throttle. So if I am on the interstate and downshift into 4th...This CEL will throw.
Any suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 &raquo;</TD></TR><TR><TD CLASS="quote"> I love little boys...</TD></TR></TABLE>
Sick-o!
Old Nov 12, 2006 | 10:22 AM
Pullig's Avatar
all you need is a universal 4 wire bosch works fine
Old Nov 12, 2006 | 10:57 AM
Hawkze_2.3's Avatar
Default Re: oxygen sensor heater problem (WhiteBB2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteBB2 &raquo;</TD></TR><TR><TD CLASS="quote">
Any suggestions? </TD></TR></TABLE>
If the O2 is good, then it'll have to be something else messing up the A/F ratio. Check timing, fuel pressure, etc... You're OBD1 right, so you only have 1 O2 in front of the cat so it's not that.
Old Nov 12, 2006 | 11:04 AM
WhiteBB2's Avatar
If the O2 is good, then it'll have to be something else messing up the A/F ratio. Check timing, fuel pressure, etc... You're OBD1 right, so you only have 1 O2 in front of the cat so it's not that.</TD></TR></TABLE>
Yes, Its is OBD1. Timing is set correctly...Just had that all checked out.
Old Nov 12, 2006 | 01:25 PM
M2B4's Avatar
well my o2 will be in 2 morrow so ill replace that and let yall know whats up. gay code 41
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteBB2 &raquo;</TD></TR><TR><TD CLASS="quote">I apologize for making the comment "I love little boys..." at you I meant to say "WHITE - FTMFW" but i was DRUNK </TD></TR></TABLE>
I knew you were drunk when you were on
Old Nov 12, 2006 | 07:11 PM
O2 sensors are the number one misdiagnosed and O2 sensor codes are the #1 misdirected codes from your ECU. If the engine is too rich or too lean, more than the O2 sensor can direct and it stays rich or lean then your CEL will come on with an O2 code, there is nothing wrong with it. You need a scope and you need to force the O2 sensor rich and lean to prove that it works, if it cannot control fuel delivery then you have a different problem, not enough fuel, weak fuel pump, bad MAP, dirty injectors OR too much fuel, leaky injector, restricted fuel return line, leaky fuel pressure regulator on and on, spend your money an some scandata at a shop instead of throwing parts at it, even the TPS can be bad.
Cap'N Chronic
Dec 3, 2011 05:44 AM
DA-VISION-763
Jul 5, 2008 03:36 PM
k24a4kid
Jan 24, 2005 10:05 AM
CapnChunk
May 1, 2003 06:47 AM
