Oil change problem
Old Nov 8, 2006 | 04:05 PM
cbbturboh22's Avatar
Default Oil change problem
I am trying to get the screw out to empty my oil and I can't get it to loosen. What can I do?
Old Nov 8, 2006 | 04:24 PM
LilBoi's Avatar
Default Re: Oil change problem (cbbturboh22)
had the same problem last week. The threads on the bold has been stripped. What you're going to have to do is get a whole new pan and gaskets. It'll run you about $200. You need to take off the down pipe and then take off the 18 bolts on the pan in place. But before you do that, you need to empty the tank. A simple drill will be enough power to eat throught the metal and drain the pan.
Old Nov 8, 2006 | 04:47 PM
korney's Avatar
Default Re: Oil change problem (LilBoi)
or, I think you can buy some sort of socket, or something like those gator grips or something to hold it and get it off. try that first, if it doesn't work, then you might have to do what Lilboi said....
Old Nov 8, 2006 | 05:14 PM
redtop22's Avatar
Why would you need to replace the entire pan?
If indeed the threads have been stripped, I'd suggest getting the pan off and going to a machine shop to see what they can do. They can probably repair the threads on the pan, and then just pick up a new bolt.
Old Nov 8, 2006 | 06:29 PM
94Vtecluder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilBoi &raquo;</TD></TR><TR><TD CLASS="quote">had the same problem last week. The threads on the bold has been stripped. What you're going to have to do is get a whole new pan and gaskets. It'll run you about $200. You need to take off the down pipe and then take off the 18 bolts on the pan in place. But before you do that, you need to empty the tank. A simple drill will be enough power to eat throught the metal and drain the pan. </TD></TR></TABLE>
Nah nah foo, ay0 check dis whatchu needs to do foh realz is buy a new whip. Dat's guaranteed tuh fix all y0 problemz.
LOL wtf are you talking about man. Just get some WD40 and a socket set. I believe it's a 10mm bolt, and I've never seen a bolt strip, or round to the point where even a socket set won't get it. Try that and when your done you might also want to invest in a new bolt.
Old Nov 8, 2006 | 06:37 PM
ludesleep's Avatar
Default Re: Oil change problem (94Vtecluder)
Also, and I know this will suck, but drive the car around till it gets to operating temps..then get and a break it loose. Come back later and drain it when its cool down.
Old Nov 8, 2006 | 10:13 PM
Marz's Avatar
WORD
Old Nov 9, 2006 | 10:02 AM
ilovemydc5's Avatar
Default Re: Oil change problem (Marz)
yeh i did have the same problem also in my bro's 89 integra had to get a new oil pan an gaskets sucks but his bolt came off but it would go back in but oil kept dripping from the bolt tryed a bigger one didnt work either so we bought another oil pan an gaskets. good looking out lilboi
Old Nov 9, 2006 | 11:41 AM
nonvteclude's Avatar
Default Re: Oil change problem (96Accordh22)
or if none of those work you can go to sears and get a bolt out. it grip rounded off bolts
Old Nov 9, 2006 | 11:46 AM
doubledeucehatch's Avatar
Tell your dad that you can't get the bolt out and you'll have to order a new jdm h22a
Old Nov 9, 2006 | 03:08 PM
jzobie1's Avatar
Default Re: (prelude252)
Drill a new hole in the pan and weld a bung on it. It will also stop thieves from stealing your oil. Ha ha just get a set of bolt extractors like has been already mentioned at Sears.
HyphyBB6
Apr 13, 2009 05:18 PM
bopbop93030
Dec 30, 2008 10:02 AM
stareatsun
Nov 18, 2004 08:23 PM
Surreal
Mar 9, 2004 06:49 PM
liquid51
Jun 5, 2003 09:40 AM
