v-tec problem
Old Nov 8, 2006 | 11:03 PM
h22silvia's Avatar
Default v-tec problem
check my v-tec silenoid and cleaned it up. pulled my oil pan and clean the oil pick up.change the oil and put syntetic oil. check the wiring it has power. check all this stuff already still cant figure whts wrong. vtec dnt kick in i have a h22a on my car. it runs strong no problems besides my vtec. help fellow tuners. wht could be the cause
Old Nov 9, 2006 | 02:18 AM
Revi's Avatar
Default Re: v-tec problem (h22silvia)
Did it recently stop working or is this a swap that you can get VTEC to work?
Old Nov 9, 2006 | 04:54 AM
kulrevon's Avatar
does it rev past 6500?
Old Nov 9, 2006 | 07:30 AM
M2B4's Avatar
Default Re: v-tec problem (kulrevon)
check the ecu connections then grab a multimeter and check for an open in the wire. i was getting some resistance with my wires but there was an open. and make sure you put it in the right pin on ecu.
Old Nov 9, 2006 | 07:59 AM
94Vtecluder's Avatar
Default Re: v-tec problem (M2B4)
https://honda-tech.com/zerothread?id=830163
h22silvia
Nov 25, 2006 11:10 AM
streetracerjoey210
11
Sep 23, 2006 03:53 PM
tuckin15s_8315
Sep 28, 2005 10:12 PM
B20_SI_CRX
21
Jun 8, 2005 10:03 AM
spoonef
Feb 28, 2003 10:01 AM
