v tec problems
Old Nov 8, 2006 | 08:36 PM
ncsuprelude's Avatar
Default v tec problems
ok so i had the h23 in my lude and swapped it out with the h22a v tec. so i get it in and it is running fine with the h23 ecu in it. when i get the p13 ecu and switch it out it throws the two error codes of courses. code 21 and 22 v tech. thats the pressure switch and solenoid. so i get code 21 to go away after i wire v tec but its still throwing code 22 the pressure switch. and get this. when i have the p13 ecu in it it starts chugging and crap with the check engine light on but as soon as swap the ecu out with the ecu from the h23 it runs fine. so is it something wrong with the ecu and the pressure switch. someone please help me. i need help. thanks. its running in limp mode with the p13 ecu as well. thanks
Old Nov 9, 2006 | 06:00 AM
Default Re: v tec problems (ncsuprelude)
does anyone have any clues
Old Nov 9, 2006 | 06:18 AM
JasonST's Avatar
What year is the engine and ecu? Both obd1 or obd2? Make sure u got the pressure switch wired up, or else ur Vtec won't run.
Old Nov 9, 2006 | 07:15 AM
M2B4's Avatar
Default Re: v tec problems (JasonST)
are u using the h23 or h22 injectors? did u wire the wire for vtec pressure switch? check make sure your topped off on oil. and double check the connections at the ecu.
Old Nov 9, 2006 | 07:57 AM
Default Re: v tec problems (M2B4)
im using h23 injectors and yes i wired the pressure switch but i didnt top it off with oil because it was already bolted on when i got the engine. you say double check the connections at the ecu but how do i know which wires are for the pressure switch
Old Nov 9, 2006 | 07:58 AM
94Vtecluder's Avatar
https://honda-tech.com/zerothread?id=830163
Old Nov 9, 2006 | 08:00 AM
so would you suggest getting a new pressure switch
Old Nov 11, 2006 | 06:44 PM
M2B4's Avatar
check for an open in the wires and check and make sure your getting ~10 volts of power at the switch.
Old Nov 13, 2006 | 08:23 PM
and what should i do if its not getting the 10volts
Old Nov 13, 2006 | 08:33 PM
M2B4's Avatar
if your 100% sure u tested it right. test the blue/blk and black if no 10v there test the blue/blk and a body ground if 10v there then your black ground wire is bad replace that. if not 10v then you need to check for open in wires check around firewall see if the wires got scuffed maybe touching the frame and grounding out. if still nothing you can try a friends ecu and/or get a new switch.
Old Nov 13, 2006 | 10:22 PM
tegman85's Avatar
i am not sure about the p13, but on my p28 for my ls/vtec i bridged two pins on my harness with a small peice of wire and it kinda bypasses the switch i guess. dont remember which pins it was though.
First Prelude
Jan 15, 2015 03:44 PM
holmesnmanny
Oct 29, 2011 06:43 AM
prime-R
16
Apr 11, 2009 05:33 PM
lshatch92
Mar 27, 2006 10:04 AM
spyderracing
15
Oct 21, 2004 05:49 PM
