S300 Boost control question
Old Nov 13, 2006 | 05:05 PM
'Lude01's Avatar
Default S300 Boost control question
Ok I took my S300 Hondata to a shop to get the boost control option installed, and I got it back today. I was just wondering is there any way to tell that the boost control has been installed by opening up ECU and looking inside? I opened mine up and everything looked the same, I don't see anything added inside? Is that only a software upgrade or there should be new hardware inside the ECU?
Old Nov 13, 2006 | 07:29 PM
'Lude01's Avatar
Anthony, I'm sure you know more about this
Old Nov 14, 2006 | 10:04 AM
pizzamanprelude's Avatar
Default Re: S300 Boost control question ('Lude01)
did s300 not come with boost control? i bought mine off here and i dont run boost but i remember seeing it in the editor
Old Nov 14, 2006 | 10:07 AM
Project:PULL's Avatar
Default Re:
Did you just get turbo installed, thus needed a retune?
Old Nov 14, 2006 | 10:55 AM
PrecisionH23a's Avatar
Default Re: ('Lude01)
Here is what needs to be modified in order to run the boost control.
Old Nov 15, 2006 | 06:28 AM
Default Re: (PrecisionH23a)
precision, do you know if that ever came as standard in the s300 at any point, my laptop is down at the mo but i thought i had the function in the editor, or does that function just sit there untill you try to use it and then it tells you that you need more parts?
Old Nov 15, 2006 | 07:48 AM
BB2H22's Avatar
Default Re: (pizzamanprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pizzamanprelude &raquo;</TD></TR><TR><TD CLASS="quote">precision, do you know if that ever came as standard in the s300 at any point, my laptop is down at the mo but i thought i had the function in the editor, or does that function just sit there untill you try to use it and then it tells you that you need more parts? </TD></TR></TABLE>
Mine does. Its about a year old.
Old Nov 15, 2006 | 08:27 AM
The updated S manager has the boost capabilities but the socketing and parts are extra when puchasing the s300.
Old Nov 15, 2006 | 08:35 AM
thanks for the reply, i'm not using boost at the minute but the guy i bought it off was turbo so i would think he payed for it when he bought it, just wasn't sure if it was there as standard, i knew you needed to buy it for s100 and 200 guess you have to pay for it with the s300 aswell. cheers
Old Nov 15, 2006 | 08:52 AM
Wait, are you talking about the boost option or boost control?
The s100/200 units originally came in non-boost (s100/s200) and boost(s100b/s200b. The s300 has the boost feature but the boost controller option is an upgrade.
Hondata just lowered the price of the s100b units down to $195 from $450 for those of you interested in the unit
Old Nov 15, 2006 | 11:05 AM
kulrevon's Avatar
So to clear it up the boost feature is being able to fuel a boosted engine beyond the honda sensor (ie. gm 3 bar map)
The boost option(controller) is the ecu being able to control the boost of the engine.
Thats correct right?
Old Nov 15, 2006 | 11:11 AM
Default Re: (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">So to clear it up the boost feature is being able to fuel a boosted engine beyond the honda sensor (ie. gm 3 bar map)
Thats correct right?</TD></TR></TABLE>
The boost feature allows you to edit fueling/ignition for past 0psi.
And you are correct about the controller. It regulates the boost in conjunction to the wastegate just as other electronic boost controllers do.
Old Nov 15, 2006 | 08:11 PM
97 Sleeper's Avatar
i dont see the S100b on the hondata website?? or am I missing something here??
Old Dec 3, 2006 | 09:17 PM
'Lude01's Avatar
Default Re: PrecisionH23a
Anthony, by modified do you mean those parts have to be replaced with different ones, or are those the parts that have to be inside ecu once boost upgrade is added? I looked inside mine and I have all the components shown.
and thanks for the help
Old Jul 10, 2007 | 06:15 AM
Default Re: PrecisionH23a ('Lude01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ’Lude01 &raquo;</TD></TR><TR><TD CLASS="quote">Anthony, by modified do you mean those parts have to be replaced with different ones, or are those the parts that have to be inside ecu once boost upgrade is added? I looked inside mine and I have all the components shown.
and thanks for the help </TD></TR></TABLE>
PR4 ecu's already have those components in the ecu. All other ecu's you have to add those in. We've got the components here if any of you guys need them as well as the GM solenoid.
sikasscivic
May 18, 2011 04:18 PM
eflove
Engine Management and Tuning
Aug 5, 2008 10:04 PM
TehGhett0P1mp
May 23, 2008 09:20 PM
