Issue with ignition getting stuck
Old Dec 22, 2013 | 06:03 AM
Nasty J's Avatar
Default Issue with ignition getting stuck
Hello all, thank you for reading my post. I have a 1998 Prelude that I am having an issue with. If I turn the key all the way to the 0 mark, the key gets stuck and I am unable to turn it to again without a ton of trouble. My question is do I need to replace the ignition lock cylinder AND the ignition switch? Meaning getting a new computer and everything. Or can I just replace the cylinder itself? Thanks.
Old Dec 22, 2013 | 08:09 AM
Sparksman's Avatar
Default Re: Issue with ignition getting stuck
I know 5th gens had a ignition recall, may or may not be related. Ive never been in a 5th gen, do the have a key release button? Try wiggling the wheel to see if that helps.
To replace the ignition you have to buy a new one w/key and have a Honda dealership flash the ecu's immobilizer to sync with the new ignition and key.
Or if you're state allows you can go Obd1 which in the long run is better. All thats needed is the ECU and adapter. Which is probably about the same amount of money as having Honda flash you're old one. But if you "need" to pass emissions stay obd2.
Or find a 5th gen for sale for parts on craigslist, get the keys, ignition, ECU, and swap into you're car. Problem solved.
Old Dec 22, 2013 | 08:46 AM
Nasty J's Avatar
Damn. That's what I was afraid of. Sucks that I have to buy everything.
Old Dec 24, 2013 | 01:20 PM
Sakanora's Avatar
Try sparksman original suggestion first, wiggle the steering wheel and turn the key, often the ignition locks with the steering wheel.
Old Dec 24, 2013 | 05:06 PM
awesomeguy641's Avatar
Step 1 buy a new cylinder lock
Step 2 bring it to honda/ lock smith so.they can program the new key
Step 3 start the car end of story
Dekorum
10
Sep 17, 2018 05:29 AM
mechan-chick
Honda Civic (2001 - 2005)
Feb 8, 2017 08:46 PM
cclair
May 1, 2015 03:37 PM
rugimpy
Aug 21, 2012 10:12 AM
BB1LOViN
Aug 28, 2008 07:02 AM
