engine light that is on without throwing a code?:S
Old Nov 15, 2013 | 05:44 PM
caddoo ltd's Avatar
Default engine light that is on without throwing a code?:S
all original 1999 base model 307,000km . engine light is on, when i go to pull the code it reads like the dash light isnt throwing any code at all!! i need this light off to pass emissions in my area. what can i do apart from delete the light itself:S??
Old Nov 15, 2013 | 08:08 PM
Black93Lude's Avatar
Default Re: engine light that is on without throwing a code?:S
Your code reader says there are no codes? Something isn't right...
Old Nov 16, 2013 | 06:53 AM
motoxxxman's Avatar
what are you using to read the codes? you need to use a scan tool, with the ignition on. parts stores do this for free.
Old Nov 18, 2013 | 04:22 PM
preludeNApower's Avatar
No code usually means bad PCM
If your scanning it right
Jerkface38
Honda Civic (2001 - 2005)
Mar 28, 2013 04:52 PM
jdm-hondacura
Oct 18, 2006 02:06 PM
ultraforce77
Aug 7, 2004 10:17 AM
