control arm
Hello, i broke some kind of arm that attaches to the control arm. its for a 2000 prelude. i havnt been able to check out more of it beside it being broken at the bolt on the control arm. not sure if that the reason why my tire was bent out. i slid on ice and hit the curb and havnt gone through it all yet. if anyone knows what that arm is call that would help alot tho
Post up pics and we can see what broke, tell you what it is and possibly spoon fed you some part numbers depending on who is in what mood after you post pics.
Thats a front driver side radius rod. You will need to replace that radius rod, and the bushings at the front cross member, the shims that shim that bushing. Now. with that said you will also have to replace the front bushings and shims on the passenger side as well, even if you are not replacing that particular radius rod. This is becuase as soone as you remove the driver side radius rod, the bushings will be squished so much that when you go to put hte new radius rod in you willl have difficult time shimign it correctly. By replacing both side bushings and shim, you will have an easy time getting the new raidus rod in and the correct geometry setup.
The part numbers for those parts are:
51352-S30-013 ROD, FR. RADIUS 2 $58.57 $42.87
and you will also need new bolts----> 2 of them - 90178-SM4-013 BOLT, FR. RADIUS ROD (12X31) 4 $7.52 $5.50
The bushings and shims are the parts below, i just copied and pasted them from a parts site.
51381-SX0-013 BUSH, FR. RADIUS ROD (RR) (HOKUSHIN) 2 $12.40 $9.08
51391-SX0-013 BUSH, FR. RADIUS ROD (FR) (HOKUSHIN) 2 $12.28 $8.99
51394-SM4-010 WASHER, CASTER ADJUSTER 2 $4.87 $3.56
51398-S30-000 COLLAR, RADIUS ROD 2 $7.08 $5.19
51399-S30-000 WASHER, FR. RADIUS ARM (53MM) 4 $5.75 $4.21
90303-SF1-003 NUT, SELF-LOCK (12MM) 2 $4.52 $3.31
And there you have it. You have the correct name for the part that broke, the correct part numerbs as well as a pricing list to go by
corpsebesideme
11
Aug 21, 2016 01:11 AM
spineshank76
Suspension & Brakes
Jan 24, 2008 05:43 PM
thisboyjulio
Oct 23, 2006 08:34 PM
PA MATT
Oct 23, 2003 06:55 PM
