Help Plz, time sensitive question?
Old Sep 16, 2013 | 05:33 PM
Sparksman's Avatar
Default Help Plz, time sensitive question?
I also posted this in the engine management/tuning section. But I thought a post here might yield some results since more people visit this section.
Ok so I bought a Neptune/Demon RTP package as some of you already know. It just dawned on me that I already have a AEM wide band.
I dropped off my virgin Po6 to be socketed and the demon installed a day or two ago. Since its already been dropped off I would like to know exactly where I plug/solder the wire"s" into the ecu or the demon? I need to get this info to him ASAP, he build computers for a living but isnt into cars.
I dont have in front of me at the moment, so any pictures would be incredibly helpful!
The model number for the wide band is 30-4100 and is only a few months old new in the box.
There are two extra wires:
-White 0-5V Output
-Blue Serial Output
Also Ive read places the certain resistors are to be removed for logging with the wideband. Is this true? If so which ones?
Any help would be greatly appreciated!
Old Sep 16, 2013 | 10:32 PM
motoxxxman's Avatar
Default Re: Help Plz, time sensitive question?
Originally Posted by motoxxxman
j12 resistor is to be removed always, located on the top of the board, when holding with the plugs on left side it will be located near the bottom left corner of the left side long white thing (injector driver).
nothing gets soldered into the demon or the ecu to use the wideband. you just splice the white 0-5v output wire into the car's d14 wire (ecu harness, will be a white wire)
taken from the same thread in the ecu section
tablecivic
Engine Management and Tuning
Nov 6, 2014 11:14 AM
Sparksman
Sep 17, 2013 01:36 PM
rev-speed
Dec 28, 2005 05:00 PM
tibbor
Feb 23, 2004 09:30 PM
