Dumping Fuel
Old Oct 26, 2013 | 01:23 PM
PABB4's Avatar
Icon2 Dumping Fuel
Hey guys,
Looking for some advice for my fuel / spark system.
H23 block h22 vtec head
Bore 30 over
Stock fuel pump and injectors and rail
Reg NGK plugs
Stock wires, cap and rotor
The Problem: At start up a good amount of black smoke out the exhaust, after it is at operating temp, black smoke will pour out over 4200 rpm.
What i dont understand is if it is dumping to much fuel, or is it not burning all the fuel in the camber?
Is the fuel regulator adjustable? Or do they make an adujustable one?
Do I need to upgrade my plugs, wires, coil?
Sugguestions Please and Thank You!
PABB4
Old Oct 26, 2013 | 05:54 PM
snobordboy's Avatar
Moderator
Default Re: Dumping Fuel
What computer are you using on this setup?
Honestly the first thing would be to get it tested with a wideband 02 sensor, and see how rich/ lean it actually is. But when doing that, might as well get it tuned, which would involve a chipped ecu or programmable ecu system.
Old Oct 27, 2013 | 06:57 AM
PABB4's Avatar
I am using a stock h22 5 speed ecu. I contact the guys at TPG tuning (local tuning shop) and they said they could probably help out with the use of chrome? I'm meeting with them on Tuesday and see what comes of it.
Thanks
Old Oct 27, 2013 | 07:11 AM
98vtec's Avatar
moderator emeritus
tuning would only be a bandaid. It needs to be fixed before tuning.
I'd put a fuel pressure test gauge on it and see what its doing.
Old Oct 27, 2013 | 02:36 PM
Apex1972's Avatar
might need a new distributor.
Old Oct 27, 2013 | 04:36 PM
motoxxxman's Avatar
^yup^
it definitely should not be running that rich with a stock ecu.
is the cel on? are there any trouble codes stored?
Old Oct 27, 2013 | 08:32 PM
holmesnmanny's Avatar
#1 reason for running rich is an exhaust leak
Old Oct 29, 2013 | 04:24 PM
PABB4's Avatar
No stored codes, No CEL on. No exhaust leaks.
Why would you think that?
Old Oct 29, 2013 | 08:30 PM
98vtec's Avatar
moderator emeritus
Fuel pressure gauge. Eliminate possible issues with data and move on.
Old Oct 30, 2013 | 07:09 AM
Bouckaroo's Avatar
What stock ECU are you using? You issue IMO is related to the stock ecu not being able to adjsut itself for your setup, as your current setup will require some serious tuning to make it run well.
i would be looking into that before anything.
Old Oct 31, 2013 | 03:39 PM
PABB4's Avatar
I am using a 94 prelude h22 vtec ecu, I'm not sure of the ecu code.
I am doing a fuel test on it on sunday i'll let you guys know how it turns out.
Old Oct 31, 2013 | 07:23 PM
motoxxxman's Avatar
if fuel pressure is good, I would start to look into the o2 sensor. because if it's really running that deathly rich, it should be maxing out the fuel trims to full negative and throwing a cel and trouble code. but you said there are no codes. so something must be up with the o2 sensor not registering properly.
stupid question, but the o2 sensor is currently in the exhaust BEFORE the cat, right?
and are you absolutely sure the ecu you're using is completely stock, virgin, not chipped, not modified in any way shape or form?
Old Nov 1, 2013 | 10:22 AM
PABB4's Avatar
It is before the CAT. No i am not sure, it does not look tampered with however I bought it used so I do not know.
Old Nov 1, 2013 | 10:23 AM
Bouckaroo's Avatar
Can you post the code of the ecu you are using?
or pics of it on the sides and inside if possible?
Shoey
Feb 22, 2010 11:22 AM
k24killer
Aug 22, 2008 11:26 AM
Lmgrcivic
Jan 22, 2005 06:04 PM
XzzYzzX
13
Nov 9, 2004 07:50 AM
631 Teggy
Dec 17, 2002 10:04 AM
