which flywheel
Old Feb 28, 2007 | 08:32 AM
mannyb16's Avatar
Default which flywheel
hey guys i have read and searched and but i still cant make up my mind which is the best flywheel for a daily driver and everyonce in a while race it on streets. i have I/E/H/ if that matters, what would be best 8-10 or 12 pounds plz help i need a new clutch and jsut throwing in a flywheel at the same time thanks for all your help in advance. im lookin to get exedy stage 2 clutch and a fidanza flywheel thanks
Old Feb 28, 2007 | 08:49 AM
98vtec's Avatar
moderator emeritus
Default Re: which flywheel (mannyb16)
depends. I would recommend no less than 12lbs for a daily driver. When you are in traffic, any less than that and it just gets a little annoying. I'm basing my opinion from driving both 12lbs and 8lbs and liking my 12lbs alot better.
for track use, its fine to get a really light one.
Old Feb 28, 2007 | 09:35 AM
mannyb16's Avatar
Default Re: which flywheel (98vtec)
ok thanks i appreciate it any other opinions the more the better thanx
Old Feb 28, 2007 | 09:59 AM
tacticalcustoms's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">depends. I would recommend no less than 12lbs for a daily driver. When you are in traffic, any less than that and it just gets a little annoying. I'm basing my opinion from driving both 12lbs and 8lbs and liking my 12lbs alot better.
for track use, its fine to get a really light one.</TD></TR></TABLE>
which flywheel are you using now(12 LB one)?
Old Feb 28, 2007 | 10:07 AM
98vtec's Avatar
moderator emeritus
Default Re: which flywheel (tacticalcustoms)
yes
Old Feb 28, 2007 | 10:32 AM
spun311's Avatar
I've got an 8lb fidanza flywheel on my prelude and it was my daily driver. I didn't think it was too big of an adjustment to drive. It was mainly the stage 2 clutch that was the pain.
Old Feb 28, 2007 | 11:34 AM
user 720822-1's Avatar
Default Re: which flywheel (spun311)
I've just, about 1 min. ago , ordered a Competition Clutch Stage II and their Lightweight Flywheel. The Flywheel weighs 13.79 lbs. Still 8.1 lbs lighter then OEM. I think this is the right setup for me (having H22 I/H/E and some other mods, but nothing special at the moment).
This weight is ideal for daily-driving and sometimes kicking his ***. But for me it's important to drive is "like" oem, so not holding the gass constantly when I'm near the trafficlight.
About the clutch. Reconsider the Exedy. A lot of ppl didn't liked it, also the quality seems to be far less then a Clutchmaster or a Comptition Clutch. I've got my combo for 499 shipped
Good luck
Old Feb 28, 2007 | 12:10 PM
Default Re: which flywheel (Black-Engine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-Engine &raquo;</TD></TR><TR><TD CLASS="quote"> Competition Clutch Stage II
Good luck</TD></TR></TABLE>
Stage II isn't near OEM feeling. and will work your leg muscle like a Bitch.
Exedy is more like oem and would probably suit your needs alot better.
Old Feb 28, 2007 | 12:46 PM
prelude1897's Avatar
while you're changing your clutch, it'd be a good idea to change your rear main seal.
Old Feb 28, 2007 | 01:03 PM
jdmlude5
Guest
Posts: n/a
im glad to here thar fidanza is ok cause i just got the 8.5 pd 1. have not put it in yet. have u noticed any diff. like reving up faster...
Old Feb 28, 2007 | 01:24 PM
GtechPro's Avatar
Default Re: which flywheel (jdmlude5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude5 &raquo;</TD></TR><TR><TD CLASS="quote">im glad to here thar fidanza is ok cause i just got the 8.5 pd 1. have not put it in yet. have u noticed any diff. like reving up faster...</TD></TR></TABLE>
I just installed an Exedy clutch and a Fidanza flywheel a couple of days ago! I did notice a bit of a difference but nothing drastic that would require a change of my driving style. When it comes to daily driving, it's the clutch you should be worried about and not the flywheel. Fidanza gets a from me (even for daily driving).
Old Feb 28, 2007 | 01:47 PM
Default Re: which flywheel (GtechPro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GtechPro &raquo;</TD></TR><TR><TD CLASS="quote">
I just installed an Exedy clutch and a Fidanza flywheel a couple of days ago! I did notice a bit of a difference but nothing drastic that would require a change of my driving style. When it comes to daily driving, it's the clutch you should be worried about and not the flywheel. Fidanza gets a from me (even for daily driving). </TD></TR></TABLE>
sweet
Old Feb 28, 2007 | 03:39 PM
v4lu3s's Avatar
RTFM
i have used the Clutchmasters aluminum flywheel with an ACT HDSS, ACT HDR6 and now use a Competition clutch 12 lb with the Competition Clutch stage 3 clutch.
The Clutchmasters flywheels was fine, very light, very fast revs and i had to relearn how to shift a bit quicker with the faster rev drops.
The Competition Clutch flywheel is great, though it is only 6 lbs lighter than the stock 18 lbs flywheel I had.
I have never seen an accord or prelude flywheel that weights more than 19 lbs. I have also never seen a Competition Clutch or Clutchmsster Clutch that did not have similar to stock pedal feel with stage 1, stage 2, stage 3 or stage 4 setups....
jdm ek9 101
Jun 28, 2006 03:59 PM
my9thtry
Jan 11, 2006 10:17 AM
mattdenali
Sep 13, 2005 04:19 PM
jDMJeRk
Aug 21, 2003 09:15 PM
SuperRice
22
Jun 6, 2003 07:24 PM
