problem w/ swap
Old Feb 28, 2007 | 08:38 AM
FlyingDaggers's Avatar
Default problem w/ swap
I'm having a check engine light on after doing a f20dohc swap w/ h23. The CEL comes on after the engine heats up to normal temp. Does anyone know why that comes on??? is it cause of my O2 sensor or a bad header??? i did throw in an aftermarket header. the oil sending sensor is not the original...the bolt on the h23 is bigger so i cut off the wire to re-wire to the f20....throws CEL on after normal temp has been reach.....any ideas???
daggers
Old Feb 28, 2007 | 09:00 AM
kulrevon's Avatar
Default Re: problem w/ swap (FlyingDaggers)
why don't you check it? Jump the connector that is behind the radio under the dash.
Old Mar 2, 2007 | 07:38 PM
Default Re: problem w/ swap (kulrevon)
jump as in?? how do you do it??? walk me step by step...newbie to electric system....
zenon8890
Feb 15, 2009 02:49 PM
bukhumlae
Jul 13, 2007 10:00 PM
91(si)hatchey
Feb 16, 2007 09:49 PM
My292Ludes
Aug 22, 2006 07:06 PM
vteckilla7
Jul 16, 2004 01:58 PM
