Another EL question
Old Feb 27, 2007 | 06:13 PM
TylerC161's Avatar
Default Another EL question
Question:
I have a 1996 prelude chassis. Originally it was an SI auto. When the previous owner swapped to a h22a he changed the gauge cluster also. He changed it from the PRND321 Si cluster to a 1992 SI cluster.
Do I have everything I should need to be able to buy EL and just plug right in? Or would this past owner of had to of done a total removal of the 96 harness and install of 92 harness and likely sell the EL's harness, inverters, ect when he still owned the car?
Old Feb 27, 2007 | 06:34 PM
M2B4's Avatar
Default Re: Another EL question (TylerC161)
check. pull ur tweeter cover out and see if u have the silver box. if not then u need the inverter and see if theres some unused plugs on ur wire harness if so then ur still using the 96 harness.
Old Mar 1, 2007 | 07:43 AM
MrLude1's Avatar
Default Re: Another EL question (M2B4)
Question. My Lude is a '95, was an S auto, now H22A 5-spd, what all else do I need to swap in the El cluster because I've been told there's a harness, inverter & some splicing.
ajason24
Feb 27, 2009 04:40 PM
H22LUDE808
Mar 19, 2008 11:26 AM
ALLMOTORH22A
Apr 3, 2007 07:47 AM
ServiceAdvisor
Feb 6, 2007 08:16 AM
