compression test (normal)
Old Feb 22, 2007 | 03:48 PM
1dopesi's Avatar
Default compression test (normal)
My rebuilt h22a has been burning oil ever since the rebuilt (3,000miles) Someone suggested I should do a compression test to see if it was the rings I came up with 172 172 172 172 all the same
does anybody know if this is normal?
My set up
head
crower stage 2 cams
crower valves
crower springs and retainers
port and polish (gasket match)
stock bottom end
Old Feb 22, 2007 | 03:52 PM
M2B4's Avatar
Default Re: compression test (1dopesi)
well its good there all the same. i dont know about the number since youve done internal work, but my stock jdm h22 compression tested like 200 210 205 210 somethign like that
Old Feb 22, 2007 | 04:06 PM
Mydogisgone's Avatar
it's very possible that the problem lies in your rings around the pistons!
I had the same problem with my h23.
Old Feb 22, 2007 | 04:18 PM
96vtecI4's Avatar
your compressions low.
Old Feb 22, 2007 | 04:23 PM
1dopesi's Avatar
Default Re: (96vtecI4)
correct me if Im wrong but doesnt oil on my electrodes on my spark plugs mean bad rings?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96vtecI4 &raquo;</TD></TR><TR><TD CLASS="quote">your compressions low. </TD></TR></TABLE>
Old Feb 22, 2007 | 04:39 PM
SKDRCR's Avatar
Default Re: (1dopesi)
jdm h22
220 across
1dopesi, is your's a usdm h22?
ludecz's Avatar
You can try to see if its really piston rings by puting a little bit of oil in the cylinder and do a compression again. The oil will help seal the rings so if your compression rises it's the rings or you got some scaring on the walls.
Old Feb 22, 2007 | 04:40 PM
SKDRCR's Avatar
Default Re: (ludecz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludecz &raquo;</TD></TR><TR><TD CLASS="quote">You can try to see if its really piston rings by puting a little bit of oil in the cylinder and do a compression again. The oil will help seal the rings so if your compression rises it's the rings or you got some scaring on the walls.</TD></TR></TABLE>
Old Feb 22, 2007 | 04:42 PM
MecUneek's Avatar
Old Feb 22, 2007 | 04:51 PM
1dopesi's Avatar
Default Re: (SKDRCR)
This is a jdm engine
If 220 all across means I'm way low but my are all even I dont get it!!!
[QUOTE=SKDRCR]jdm h22
220 across
Old Feb 22, 2007 | 04:53 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1dopesi &raquo;</TD></TR><TR><TD CLASS="quote">This is a jdm engine
220 across
Yes, that is way low for a freshly built jdm engine.
Do the cap of oil in the cylinder test like ludecz said.
Old Feb 22, 2007 | 04:58 PM
bluedlude's Avatar
has anyone ever really compared a compression test on a stock bottom end with aftermarket, long duration cams to a compression test on the same motor but with stock cams? i would think the longer duration would affect your dynamic compression at low RPM and that would give you a lower compression reading? anyone?
Old Feb 22, 2007 | 05:06 PM
JoN2DaSoNz's Avatar
threadjack/ mines came at 165 196 200 165 for my h22a4 gotta rebuild my cylinder heads and valves =[ JG FTW!!!
Old Feb 22, 2007 | 05:07 PM
1dopesi's Avatar
could low oil cause low compression?
I guess it makes sense....
Ill just have to do it again!!!
Old Feb 22, 2007 | 05:10 PM
SteveoBA8's Avatar
Hold the throttle wide open during cranking, pull out All the spark plugs during the test.
My jdm H22a averaged 220psi
Old Feb 22, 2007 | 05:27 PM
bluedlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1dopesi &raquo;</TD></TR><TR><TD CLASS="quote">could low oil cause low compression?
Ill just have to do it again!!!</TD></TR></TABLE>
absolutely! the helms says to make sure your oil is topped off before you do the compression check.
Old Feb 22, 2007 | 06:04 PM
98vtec's Avatar
moderator emeritus
Default Re: (bluedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude &raquo;</TD></TR><TR><TD CLASS="quote">has anyone ever really compared a compression test on a stock bottom end with aftermarket, long duration cams to a compression test on the same motor but with stock cams? i would think the longer duration would affect your dynamic compression at low RPM and that would give you a lower compression reading? anyone?</TD></TR></TABLE>
well, yea. Especially if you are using stock compression. Take matts motor for instance. His crower3's drain the hell out of his compression.
longer duration = less time to build compression....right?
Old Feb 22, 2007 | 06:17 PM
lude98SH's Avatar
Default Re: (98vtec)
well u figure ur giving the engine less time to compress the mixture with a longer duration cam. Thats why they say to run atleast a certain compression piston when going with longer duration cams.
As for it actually taking away compression im not 100% sure on that.
Old Feb 22, 2007 | 06:20 PM
Missing Gears's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
longer duration = less time to build compression....right?</TD></TR></TABLE>
a larger aftermarket cam only causes a compression drop when vtec is engaged, any other time its using the smaller lobes. when checking compression you will be using the small lobes, so no it wont cause a drop.
i have never tested any usdm h22s, but all of the stock jdm h22s i have tested were between 240-260 psi. keep in mind, this is w/ a head that was sealing up 100%
add a 12:1-13:1 compression bottom end and it will max out the guage @ 300psi.
as long as you are getting within 15 psi of eacother all across, i wouldnt worry about the number. every guage will read different and some are way off.
the most important thing is that they are all close to eachother, otherwise there is a problem somewhere. if they are all exactly the same or even within 15 psi you are good to go
Old Feb 22, 2007 | 06:23 PM
98vtec's Avatar
moderator emeritus
Default Re: (Missing Gears)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Missing Gears &raquo;</TD></TR><TR><TD CLASS="quote">
didnt even think of that, thanks
what about the crowers with modified idle lobes?
Old Feb 22, 2007 | 06:26 PM
bluedlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Missing Gears &raquo;</TD></TR><TR><TD CLASS="quote">a larger aftermarket cam only causes a compression drop when vtec is engaged, any other time its using the smaller lobes. when checking compression you will be using the small lobes, so no it wont cause a drop.
the most important thing is that they are all close to eachother, otherwise there is a problem somewhere. if they are all exactly the same or even within 15 psi you are good to go </TD></TR></TABLE>
very true, where was my brain .
my USDM has always read between 210 and 200 PSI
Old Feb 24, 2007 | 08:56 AM
1dopesi's Avatar
So, my compression is still really low....... if my crower2 cams dont drain compression
170 172 172 172 anybody?
Old Feb 24, 2007 | 01:06 PM
doubledeucehatch's Avatar
Use a different guage because if its the same all the way accross then it could be higher and the tester is just messed up. Its a longshot but its worth a try.
turbo_ef4
Feb 17, 2006 11:55 AM
foesicks
Jan 8, 2003 03:16 PM
311
Dec 14, 2002 12:18 PM
LudeyKrus
Nov 7, 2002 09:44 PM
lsvtec42
Dec 6, 2001 12:39 PM
