reprogram ecu?
Old Feb 26, 2007 | 06:48 AM
royalfelix's Avatar
Default reprogram ecu?
how is it that you reprogram your ecu. like when you do something new to your car you gotta have the key in the switch then take off the battery something like that im not sure, let me know please. many thanks
Old Feb 26, 2007 | 06:52 AM
bluedlude's Avatar
Default Re: reprogram ecu? (royalfelix)
its just resetting the ECU. all you have to do is disconnect the battery.
Old Feb 26, 2007 | 07:22 AM
royalfelix's Avatar
Default Re: reprogram ecu? (bluedlude)
i thought it had to be with the key in the ignition or something?
Old Feb 26, 2007 | 07:32 AM
bluedlude's Avatar
nope, nothing special
Old Feb 26, 2007 | 05:43 PM
jdmlude5
Guest
Posts: n/a
the rite way to reset your ecu. you take out your clock radio fuce in the fuse box under the hood. u just take it out 4 about 30 sec.
Old Feb 26, 2007 | 07:14 PM
MLBZ521's Avatar
Default Re: reprogram ecu? (jdmlude5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude5 &raquo;</TD></TR><TR><TD CLASS="quote">the rite way to reset your ecu. you take out your clock radio fuce in the fuse box under the hood. u just take it out 4 about 30 sec. </TD></TR></TABLE>
Seriously?? You're joking..
What would that do to your ECU?
And why wouldn't disconnecting the battery reset it then?
Old Feb 26, 2007 | 08:49 PM
Flip.'s Avatar
Default Re: reprogram ecu? (MLBZ521)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLBZ521 &raquo;</TD></TR><TR><TD CLASS="quote">
And why wouldn't disconnecting the battery reset it then?</TD></TR></TABLE>
Both ways do the same thing
Old Feb 26, 2007 | 09:33 PM
Honda_Fanatic's Avatar
Default Re: reprogram ecu? (Flip01)
either way works.
Old Feb 26, 2007 | 09:57 PM
alphajesse's Avatar
There is no reason to do this at all.
Unless you like to reprogram your radio.
Old Feb 27, 2007 | 02:24 PM
jdmlude5
Guest
Posts: n/a
read the manual..... take out the clock radio fuse to reset the ecu... do some research before u act like u no somwthing....
Old Feb 27, 2007 | 02:26 PM
jdmlude5
Guest
Posts: n/a
Default Re: (alphajesse)
yes both ways do work buts its a hell of alot easier to do it that way. and that is considered the rite way...
Old Feb 27, 2007 | 03:31 PM
alphajesse's Avatar
There is no reason to reset the stock ECU. It will not improve performance. It will only ruin mileage for a day or two.
Old Feb 27, 2007 | 04:24 PM
jdmlude5
Guest
Posts: n/a
pretty much.
crxsi814
Jan 18, 2011 06:25 PM
EFstyle
Oct 5, 2007 10:21 PM
tbuck23
Apr 1, 2007 05:50 PM
gutterslide
Jun 3, 2005 09:44 PM
Fatty_1775
Aug 5, 2003 05:37 AM
