Knock sensor H22A
Old Feb 22, 2007 | 05:50 PM
Metal Head's Avatar
Default Knock sensor H22A
hello guys, 1993 Honda prelude H22A swap.
I am getting a code for knock sensor, when the car is cold, the car runs fine, hit vtec fine in all. After it warmes up, The CEL pops on, and its the knock sensor code. When CEL pops on the car runns like ***. ( JDM ECU) it also throws tracktion control code....
The car also has an up and down idle 900 1300 900 1300 up and down up and down
which sound to me like the AIC valve, but no code, so mabey its not that.
So im asking you guys to knowlage me on the knock sensor and my problem.
I remmeber hearing on some cars, deleteing the knock sensor actually gains a little power?
So I was thinking, mabey i can fix the problem by, selling my JDM ECU and buying an ecu from phareable.net and chip and telling them to delete knock sensor.
Suggestions, knowlage, advice, opinions all welcome.
Please help a fellow tuner out
Old Feb 22, 2007 | 06:00 PM
98vtec's Avatar
moderator emeritus
Default Re: Knock sensor H22A (Metal Head)
when you get a knock sensor CEL, the ecu retards the timing to lower the cylinder pressure and it dumps more fuel to keep everything cooler. This is why you feel a power loss.
One way to delete the knock sensor is to get a p28 ecu and have it tuned to your motor with a program like hondata, crome...etc.
You will not gain any power just by deleting it.
Old Feb 24, 2007 | 11:08 AM
alphajesse's Avatar
What ECU are you running?
Old Feb 24, 2007 | 12:34 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Metal Head &raquo;</TD></TR><TR><TD CLASS="quote">
Please help a fellow tuner out </TD></TR></TABLE>
The knock sensor is a common problem for some JDM h22a's.
My car was having the same symptoms as yours, I just forked out the money
and replaced the KS and it was night and day after that.
Old Feb 24, 2007 | 12:55 PM
doubledeucehatch's Avatar
If you have money get p28 or p06 chipped with h22 basemaps and do away with knock. Just a suggestion but I understand money doesn't grow on trees. Then u can also block off the egr too.
Old Feb 24, 2007 | 05:53 PM
Metal Head's Avatar
Default Re: (prelude252)
yea imma get a p28, i bought a new knock sensor, but, the wire harnedd is haggeard, so imma get the p28 chipped and do away with knock.
now u say delete egr too?
Old Feb 24, 2007 | 05:55 PM
98vtec's Avatar
moderator emeritus
Default Re: (Metal Head)
a p28 (civic ex) doesnt have EGR.
Old Feb 24, 2007 | 06:34 PM
Metal Head's Avatar
Default Re: (98vtec)
oh ok, Dee dee dee to me!
Nopw where would one buy an EGR block off kit?
Old Feb 24, 2007 | 06:36 PM
98vtec's Avatar
moderator emeritus
KMS makes a blockoff plate.
PV
Jul 8, 2008 09:16 AM
jdm_cd5
Jun 19, 2007 06:08 PM
mck26
Oct 19, 2005 09:47 AM
Fardoche
Jul 31, 2003 10:29 PM
