Installing new valves
Old Jun 21, 2007 | 07:40 AM
kornerk12's Avatar
Default Installing new valves
Is there anything you must be besides install them and adjust them ? Im talking maching wise ? Ive heard about lapping valves or something ?
Old Jun 21, 2007 | 07:55 AM
SnlpeR's Avatar
yea you could lap them with a couple of compounds
Old Jun 21, 2007 | 08:09 AM
117's Avatar
117
I would take the head and valves to a machine shop. Verify that the valve stem to guide clearance is in spec, and have them do a full valve job to ensure the sealing surfaces are perfect.
If you don't want to spend the money, you could put some Dykem on the valves and seats then very lightly lap the valves with some fine lapping compound. That'll show you the contact pattern between the valve and seat. If it's not sufficient, you'll need to have a valve job done.
The Helms manual shows how to do a check of valve stem to guide clearance, but it's not as accurate as mic'ing the stem and using a bore gauge on the guides.
Old Jun 21, 2007 | 08:25 AM
streetracer6rpt's Avatar
Default Re: Installing new valves (kornerk12)
unless u really know what ur doing,take it to a machine shop.better to spend a little money the first time,then whole lot the next
kornerk12
11
Jul 3, 2009 03:55 AM
importboi22
34
Feb 8, 2007 12:43 AM
GSRVTEC1
Oct 31, 2005 01:19 PM
D50boy
Jun 2, 2005 02:39 PM
JeffNA
May 20, 2002 06:59 AM
