Problem with brakes?!
Old Jun 27, 2007 | 02:32 PM
namax's Avatar
Default Problem with brakes?!
Something is terribly wrong with my brakes. Every so often, when I step on the pedal, it just keeps going into the floor without slowing my car much at all. I need to pump it a couple times for it to begin working. Then the next time I use it, it works fine. It used to happen every two weeks or so, but it is becoming more frequent. It happened twice today. My mechanic just replaced the rear brakes and refilled the brake fluid a few days ago, but this was happening long before I took it in. What could the problem be?
Old Jun 27, 2007 | 02:41 PM
mattsnooz's Avatar
Default Re: Problem with brakes?! (namax)
leak in your lines probably? is your brake fluid resivoir getting lower and lower?
Could be air in lines too but your mechanic should have bleed them properly I would hope
Old Jun 27, 2007 | 02:50 PM
SnlpeR's Avatar
sounds like signs of a master cylinder going bad
Old Jun 27, 2007 | 05:34 PM
fast_honda's Avatar
Default Re: (SnlpeR)
The brake lines need to be bled.
Old Jun 27, 2007 | 07:18 PM
ECX's Avatar
ECX
* B A N N E D *
I agree with both, get a buddy to help you bleed your brakes. If that doesn't solve it, next is the master cylinder. Replace it and it should be fixed.
Old Jun 28, 2007 | 04:26 AM
jaywoodz's Avatar
Default Re: (ECX)
With my exp. with hondas, I can almost guarantee you it's the master cylinder. No little leaks in the lines will cause that much of a drop in your pedal. Go to advance auto parts, pay $68 and put it in, or take it to a place and pay $100+ or so and they will put it in and re-bleed your lines, and you're set. I just did a brake master cylinder on my accord last week. Works perfect now
Old Jun 28, 2007 | 05:30 PM
InvaderTrax's Avatar
100% sure it's the MC. If there was a leak, he wouldn't be able to pump it up. It would just lose more fluid with every push. Anyway, see if you can find someone who knows how to bench bleed your new MC before you install it. Makes things 10x easier
Old Jun 28, 2007 | 07:03 PM
mattsnooz's Avatar
Default Re: (InvaderTrax)
air in lines can do the same thing, if the air bubbles just move around in system and then occasionally come back to MC.
Old Jul 16, 2007 | 04:08 PM
namax's Avatar
Default Re: (mattsnooz)
yeah it was the master cylinder, thanks guys.
Old Jul 16, 2007 | 05:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz &raquo;</TD></TR><TR><TD CLASS="quote">air in lines can do the same thing, if the air bubbles just move around in system and then occasionally come back to MC.</TD></TR></TABLE>
Air doesn't just get into the brake lines on its own. Only from improper bleeding or some kind of leak
Stance Movement
Jul 30, 2018 08:16 AM
bigrob119
Oct 18, 2009 04:02 PM
pedroa06
Sep 3, 2009 06:23 PM
90 integraian
Suspension & Brakes
Sep 25, 2008 05:11 AM
94lspower
May 19, 2007 08:42 PM
