is this safe?
Old Jun 22, 2007 | 08:35 AM
dek1mfk's Avatar
Default is this safe?
can i use a stock h222 head with an h22 block that has jdm high compression pistons?
the head is stock and the block is stock besides the pistons
also, will it matter if its a h22a4 block with a h22a1 head?
Old Jun 22, 2007 | 09:48 AM
NirVTEC's Avatar
Default Re: is this safe? (dek1mfk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dek1mfk &raquo;</TD></TR><TR><TD CLASS="quote">can i use a stock h222 head with an h22 block that has jdm high compression pistons?
H's are H's......What are JDM HIGH COMPRESSION pistons? You mean HIGHER?
Old Jun 22, 2007 | 10:07 AM
vinuneuro's Avatar
It's safe.
Old Jun 22, 2007 | 10:33 AM
Finest's Avatar
Default Re: is this safe? (:=:NirVTEC:=:)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by :=:NirVTEC:=: &raquo;</TD></TR><TR><TD CLASS="quote">
H's are H's......What are JDM HIGH COMPRESSION pistons? You mean HIGHER?</TD></TR></TABLE>
Probably some Type S pistons. Either way, you'll be fine.
Old Jun 22, 2007 | 10:47 AM
98vtec's Avatar
moderator emeritus
just be sure to use a headgasket for an a4 (open deck)
RACEPAK
May 24, 2008 11:03 PM
EJ1_203
10
Sep 28, 2007 04:28 PM
chad
Jan 4, 2004 01:57 PM
Evil_Wizard
13
Nov 10, 2003 09:14 AM
BeavisB16
Feb 22, 2003 12:28 PM
