PLX install
Old Jun 24, 2007 | 01:57 PM
lude98SH's Avatar
Default PLX install
Im reading all the posts on this however im not 100% sure how to install it. Obviously you need power and ground. However I am undersure of how to hook up my white and gray wires since i want to keep my narrowband o2 and weld in another o2 bung. I have been told i need to run a switch on the gray wire to switch the car into narrowband or turn narrowband off or something. Alittle confused to say the least. I am using hondata s300j
Old Jun 24, 2007 | 07:56 PM
esedulerp5tenin's Avatar
Default Re: PLX install (lude98SH)
you wanna run a narrow AND wideband?? why?
Old Jun 24, 2007 | 08:15 PM
A Blue Lude's Avatar
Default Re: PLX install (esedulerp5tenin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esedulerp5tenin &raquo;</TD></TR><TR><TD CLASS="quote">you wanna run a narrow AND wideband?? why?</TD></TR></TABLE>
Closed loop works pretty well?
Old Jun 25, 2007 | 05:30 AM
96vtecI4's Avatar
bump, i'm interested to.
Old Jun 25, 2007 | 06:48 PM
SteveoBA8's Avatar
Look on Plx's website for wiring info, it will tell you exactly what to do. It's less wiring if you choose to weld in another bung like you stated you are going to do.
Click on the link in the 3rd question
http://www.plxdevices.com/products/m300/faq.html
Old Jul 1, 2007 | 03:46 PM
lude98SH's Avatar
Default Re: PLX install (SteveoBA8)
well i attempted the install and im not sure how to install it because i want to be able to run both open and closed loop and run both o2 sensors. And preferablly run no switch. Everyplace i look it seems like someone does it differently..kinda confusing ...
Old Jul 1, 2007 | 03:51 PM
96vtecI4's Avatar
I plan to weld in a 3rd o2 bung. I don't know if thats something you want to do, but i thought i'd put it out there.
Old Jul 1, 2007 | 04:47 PM
lude98SH's Avatar
Default Re: (96vtecI4)
yes that is what im doing..... well 2nd technically no cat
Old Jul 1, 2007 | 07:23 PM
SteveoBA8's Avatar
Default Re: (lude98SH)
Then weld a bung just for the wideband, source your 12V acc power from the ign harness/then find a good place to ground, mount the display= done
Old Jul 1, 2007 | 08:58 PM
96vtecI4's Avatar
Yeppers. I think getting a bung welded in is easier then going through all that to trick the ecu and whatnot. Having a bung welded in will cost like $20 at most.
Old Jul 2, 2007 | 05:20 PM
lude98SH's Avatar
yes but dont u want hondata to read the a/f ratio directly ?
jdmjunkie86
Feb 14, 2008 02:57 PM
XX Boosted Si XX
Nov 21, 2005 07:48 PM
dornon13
Jun 8, 2005 04:05 PM
sol_1320
Apr 5, 2005 10:20 AM
civicgeek9
Mar 22, 2005 07:39 PM
