hard to get in reverse!!
Old Sep 14, 2007 | 12:15 AM
DrivinVtec's Avatar
Default hard to get in reverse!!
someitmes its a bitch to get in reverse. i have to put it in 1st,2nd then reverse. it can be a pita soemtimes. whats the deal.
01 prelude exzedy cluch stg1 ( im boosted)
Old Sep 14, 2007 | 12:16 AM
Hawkze_2.3's Avatar
Default Re: hard to get in reverse!! (DrivinVtec)
Low on fluid, clutch not going in all the way...etc
Old Sep 14, 2007 | 12:32 AM
DrivinVtec's Avatar
Default Re: hard to get in reverse!! (Hawkze_2.3)
ill check the fluid this weekend. does it seem like a serous issue?
Old Sep 14, 2007 | 12:38 AM
MLBZ521's Avatar
I've had the same problem.. Every once in a while my transmission decides to be stubborn and it won't got into Reverse, sometimes even 1st..
But it's never been a big deal.. Nothing that annoyed me that much.. Full fluid, nothing else wrong.. My clutch could be old though... Dunno how long it's been since it was replaced, I haven't I know..
Does it happen often enough to seem serious? Or just every once in a while it acts up?
Old Sep 14, 2007 | 12:39 AM
DrivinVtec's Avatar
Default Re: hard to get in reverse!! (MLBZ521)
just once in a while. maybe like once a day.
Old Sep 14, 2007 | 12:40 AM
Hawkze_2.3's Avatar
Mine will do that too and if I let the clutch pedal out and push it in again it works fine. Probably just a quirk with the master and slave cylinders or the clutch itself.
Old Sep 14, 2007 | 04:15 AM
Maharajamd's Avatar
5th gear syncro sleeve could be fubar. Very very common problem on 5th gens. I actually just had mine go on my 4th gen.
Old Sep 14, 2007 | 08:16 AM
DrivinVtec's Avatar
sure hope that doesnt happen to me. prolly cheaper to get new tranny then built?
Old Sep 14, 2007 | 08:43 AM
Maharajamd's Avatar
Naw. I replaced the sleeve and the gear. 180ish. you can probably get away with just replacing the sleeve, $90. Of course thats doing all the work yourself....
Old Sep 14, 2007 | 08:46 AM
DrivinVtec's Avatar
i dont know **** when it comes to trannies. lol how difficalut is it?
Old Sep 14, 2007 | 08:52 AM
Maharajamd's Avatar
Really once you have the tranny off its easy work. gotta make sure you put everything back on in the right direction in the right order. Have a Helms. I had a friend with me to help so it wasn't bad at all.
Once the tranny is off it was petty easy...
Old Sep 14, 2007 | 08:56 AM
DrivinVtec's Avatar
Default Re: (Maharajamd)
maybe once i cant go in reverse an have to push it back..then i might tackel this.
Old Sep 14, 2007 | 09:22 AM
LukieLuc's Avatar
Default Re: (DrivinVtec)
this happen to me also every couple of days, i dont think its any major problem though, all my fluid is filled ad my clutch is new. Prob... we need to flush the tranny
Old Oct 15, 2007 | 07:04 AM
ludenoob99's Avatar
sorry to bring up an old thread but i have the same problem with my 99 lude. every once in a while it will refuse to go into reverse. the clutch will be to the floor at a complete stop and it just wont let it go in. sometimes if i pull really hard it will push halfway in and grind. i just sit and shift through the other gears and wait a while then it will eventually decide to let me in.
i checked my fluid, the clutch is pretty new, i bled the system a few times to make sure that wasn't it. what the heck could be not letting it go into reverse but dosn't effect all the other gears?
Old Oct 15, 2007 | 07:15 AM
DrivinVtec's Avatar
Default Re: (ludenoob99)
well i yanked the motor out last week an i didnt have much fluid. that was my problem i think.
Old Oct 15, 2007 | 02:30 PM
mattsnooz's Avatar
I found if you roll the car forward (let off break or shift to second just to move a bit), and than go back to either 1st or reverse. It should go in after that.
duyfash0
Mar 20, 2010 11:28 AM
hpimichael02
Oct 31, 2008 09:46 AM
civicandr6
Mar 16, 2007 07:18 PM
shiux
Mar 19, 2006 06:53 PM
vti444
Jun 13, 2005 03:44 PM
