Question on launching.
Old Sep 12, 2007 | 01:13 PM
preludeh22a1's Avatar
Default Question on launching.
i got a fiberglass hood that i got from a pick a part for 26 bucks, my question here is when i launch the car it spins too much tires and it takes a while to go. (im auto h22a1) and most of the time i launched it before when i have the stock hood, it will juz be one chirp then like a jump on the line. I thought ludes are heavy so it needs to be lighten on the front because the engine is heavy.
im using 14" steel rims.
I juz need explanations about it,im thinking if i did something wrong.
thanx.
Old Sep 12, 2007 | 01:29 PM
mgags7's Avatar
You did nothing wrong by lightening your car up.
Its tough to control the launch on an auto but all I can say is get some slicks or let off the gas some.
Old Sep 13, 2007 | 05:41 AM
Default Re: (mgags7)
slicks??? i dont want to break an axle... i dont even know if my car can warm up those tires. i never do a burn out on the track. do u know how on a auto??
Old Sep 13, 2007 | 06:18 AM
nonvteclude's Avatar
Default Re: (preludeh22a1)
you could also try just some better tires, even drag radials. this is a problem alot of us go through at the track. getting traction is a pain in the ***. just get some better tires and make a couple runs to figure out the ideal launching technic for your car.
Old Sep 13, 2007 | 06:41 AM
carnot's Avatar
Default Re: (nonvteclude)
If the only modification you have made to your car is changing the hood then I don't think you need to worry about breaking an axle when using slicks. A stock h22 with an auto tranny isn't making enough power to worry about snapping an axle. I would suggest getting some slicks for those 14" rims. If you choose the slick correctly you can even change your effective gearing so the top speed in each gear is lower which should help with 1/4 mile ET. On my old H23 NA setup I did this and knocked off 0.3 from my ET. Slicks are necessary to hook up in FWD
Old Sep 13, 2007 | 09:44 PM
Default Re: (carnot)
i ran 15.6 without the fiberglass hood. full interior. so i dont think i dont have power eventhough its automatic..
Old Sep 13, 2007 | 10:56 PM
dagle's Avatar
lol how much HP u got to the wheels? cuz i dont even think the manual boosted luders are making so much power theyre breaking axles on slicks.
Old Sep 13, 2007 | 11:24 PM
DrivinVtec's Avatar
lower tire pressure
Old Sep 13, 2007 | 11:31 PM
Hawkze_2.3's Avatar
Default Re: Question on launching. (preludeh22a1)
Explanation: different road surfaces, different temperatures, different conditions, etc.. Too many variables and no, a lighter hood doesn't make that much difference.
Old Sep 14, 2007 | 02:37 PM
Default Re: Question on launching. (Hawkze_2.3)
i know it wont be a big difference with juz a hood. i thought u could break axles when u have slicks,if its not upgraded. juz wanted to be sure i wont break anything. and im not saying i have a lot of hp (i wish!)
i think what i need now is good tires.
Old Sep 14, 2007 | 02:48 PM
tgreene2098's Avatar
if you got wheel hop go with solid motor mounts......
Old Sep 14, 2007 | 05:29 PM
RAB's Avatar
RAB
In my opinion...
feather the clutch and throttle at 3500 then dump it.
Old Sep 14, 2007 | 06:09 PM
TylerC161's Avatar
Default Re: (RAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RAB &raquo;</TD></TR><TR><TD CLASS="quote">In my opinion...
feather the clutch and throttle at 3500 then dump it. </TD></TR></TABLE>
He has an auto.
y2kferari
Apr 23, 2006 03:28 PM
rice crispies
10
Jun 13, 2004 02:06 PM
98vtec
Oct 10, 2003 07:27 AM
PM-Performance
Jul 30, 2002 08:40 AM
