Bolt size?
Old Sep 8, 2007 | 02:38 PM
CHK4TIX's Avatar
Default Bolt size?
ok, does anyone have any suggestions on how to find a bolt size? I have a h23 block that apparently the crank bolt has been re-threaded and the stock bolt does not work with it any longer.
At first I thought maybe the threads have been stripped but that is not the case. The stock bolt slides in and the new threads barely touch the threads on the bolt. So if anyone can give me an idea on what size(s) I need to look for, it would be appreciated.
Old Sep 8, 2007 | 05:09 PM
CHK4TIX's Avatar
Default Re: Bolt size? (CHK4TIX)
Well I guess there are 2 different size crank shaft bolts starting in 1993 and I would assume I need the larger one
in case anyone else would like to know
90017-PT0-003 BOLT-WASHER (14X33)
90017-PY3-003 BOLT-WASHER (16X49)
Old Sep 8, 2007 | 05:18 PM
mgags7's Avatar
That is odd. Never heard of it before.
Maybe one was for the f22 and the other was h23/h22?
Old Sep 8, 2007 | 07:00 PM
CHK4TIX's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">That is odd. Never heard of it before.
Maybe one was for the f22 and the other was h23/h22?</TD></TR></TABLE>
if you do a part search on one of the many places it actually comes up just as I posted it for the h22 and the h23 in 1993.....does anyone have an extra. lol
Old Sep 8, 2007 | 09:20 PM
98vtec's Avatar
moderator emeritus
they are the same. the crank bolt for my h22 fit the f22 perfect
Old Sep 9, 2007 | 05:21 AM
mgags7's Avatar
Default Re: (CHK4TIX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHK4TIX &raquo;</TD></TR><TR><TD CLASS="quote">
if you do a part search on one of the many places it actually comes up just as I posted it for the h22 and the h23 in 1993.....does anyone have an extra. lol</TD></TR></TABLE>
I know I have an extra one, I'll look today and measure it if I can find it.
Old Sep 19, 2007 | 04:17 PM
CHK4TIX's Avatar
Ok I finally got the bolt I needed from the dealer. Just incase someone wanted to see the difference, here they are
the 16x49 bolt is on the left, the more common 14x 33 bolt on the right
Old Sep 19, 2007 | 05:02 PM
Rosko's Avatar
yeah theres deffinately two different kinds.
Old Sep 19, 2007 | 06:05 PM
mgags7's Avatar
So I'm guessing that the smaller one comes out of the factory on every engine, and the bigger one is for fuckups.
Good stuff, never knew
Old Sep 19, 2007 | 06:29 PM
CHK4TIX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">So I'm guessing that the smaller one comes out of the factory on every engine, and the bigger one is for fuckups.
Good stuff, never knew </TD></TR></TABLE>
actually, there are two different sizes FROM the factory (maybe they messed up and its their solution) . If you look up the part numbers depending on which year you use, it has the two different part numbers listed.
However, The larger sized bolt is common in accords, acura RL's, and even Honda marine engines.
Old Jul 14, 2010 | 07:41 PM
acc98ord's Avatar
This is why HT is the best honda resource
The 16mm bolt has a different part# now
90017-RJA-003 BOLT-WASHER (16X49)
http://www.hondaautomotiveparts.com
under crankshaft for the different prelude models
si0385.
Dec 12, 2016 03:23 PM
spidermancivic
Oct 14, 2012 12:13 AM
bakwudzgurl
Mar 11, 2010 07:38 AM
Motorman21
May 5, 2009 10:04 AM
DC2 to AP2
Acura TL, RL & ZDX
Nov 19, 2005 06:37 PM
